Shortcut to connect to android device
lucfig
Hi, I know we can create shortcuts to connect directly to a host with the parameters -i and -P.
However, the Host app for android do not have a password, it has just the ID. When I try to use a shortcut with just the -i, it asks for a password.
Is there a parameter fr the shortcuts that I can use to directly connect to my android device?
1
Same problem here. When trying to connect to android device via parameters -i and -p it says "Authentication rejected". If we use only -i it says "Password required"
