Opensuse Leap 15 teamviewer 12 doesn't open
It worked on Tumbleweed changed to leap 15 and now it won't open. I
Leap 15, Gnome 3.26.1 fresh install. I've switch to Xorg and disabled wayland (which broke GDM). Nothing has worked.
Is there something else that needs to be done?
  • mwelwarsky
    Same problem here, fresh installation with KDE Plasma 5. Same issue.
  • MarkusHeberling
    I have the same problem.
    What does work for me is, to download the Windows Portable Version and run that with wine. I can do remote control incoming and outgoing with that. Also I can join meetings. Unfortunately I can't create a presentation meeting. Always get "Authentifizierung gescheitert" when I try to do that. If I am a participant in a meeting and someone makes ma a presenter the application crashes.
    So if you only need the remote control options or passively join a meeting, use the windows portable version with wine. If you need to host meetings, you're out of luck at the moment...
  • achilles
    I have confirmed this works for TeamViewer 12.0.93330:
    1. Fixing the font library issue:
    Download libfreetype6-32bit 2.6.3 from the Leap 42.3 repository here. Extract libfreetype.so.6.12.3 to /opt/teamviewer/tv_bin/wine/lib/libfreetype.so.6
    Note: Using the Arch freetype library mentioned in this post does not work.
    2. Fixing the libxcb issue:
    Download libxcb1-32bit 1.11.1 from the Leap 42.3 repository here. Install the rpm with
    # rpm -i --force libxcb1-32bit.rpm
    make sure you lock libxcb1-32bit in Yast so it does not get updated.
    Alternatively you can keep libxcb1-32bit 1.13 but you need to recompile it with CFLAGS="%depflags -O1" in the specfile. I have not tried it yet but compiling the library for 32bit on 64bit systems does not seem trivial.
This Week's Leaders
