Is there a way to change is so that when you close the session it just closes and doesn't lock the computer?
Hi @dmakhoul
You can pre-define which behaviour you would like to have in your TeamViewer Settings under Extras --> Options --> Advanced --> Advanced settings for connections to other computers --> Lock remote computer:
Here is the meaning of the different possibilities:
I hope this helps you.
All the best, Esther
Hello axxe,
I meant Mac OS, not iOS.
Sorry, for the mistake, I just corrected it.
Did you mean to say iOS? I am talking about mac OS (Computer, not mobile device)
You cannot change these settings, as the automatic lock of the session is not possible for Mac OS.
If you need any further information, please let me know.
How can I change this setting on a Mac?
