Can't login on TeamViewer Windows 10
janvankuijk
Posts: 1 ✭
Most of the times I can't login on TeamViewer Windows 10. After entering my login credentials and click on 'connect' the software is doing nothing!
I uninstalled the software already a couple of times and installed it again. No difference.
Jan
Had this issue too, and clearing my password and resetting didn't work. This happened yesterday. I checked for updates, yet it says it's ok...
"Sign In" did nothing - it was not active for some time, and then at that point became enabled, yet generally nothing occured.Update: tried Connection-> Exit TeamViewer - now it works fine.
Tags: Windows 10 TeamViewer essay
