Got a Team viewer V12 License will that work fro Version 13
jack78546
Dear @jack78546,
The license in version 12 can be used with the software in version 12. If you want to use the software in version 13, you have to upgrade your license.
NataschaGerman Community moderator 💙 Moderatorin der deutschsprachigen Community
Hi @jack78546,
that typographical error could create some confusion. Is it FOR or FROM?
TeamViewer is backwards compatible. Connections from a TeamViewer 13 to a TeamViewer in version 12 should work without any issues.
From TV 12 to TV 13 will not work.
Domenico Langone
1
