Is it correct that v14.0.141353 is not compatible with IOS 10.3.3 on IPAD
i am updating from v 13.2.111907
Information-yes. Helpful-no. My iPad can no longer work with devices that are upgraded. TeamViewer decision to obsolete a class of iPads is troubling for the future.
Hi @Cartoony
Thanks for the feedback. I checked this with our developers and got the info, that iOS 32 bit devices are not supported with TeamViewer 14.
Thanks and best,
Esther
Hi Esther,
It seems, there is no solution for an ipad 4 iOS 10.3.3 and teamviewer 14 to make them comunicate. The suggested quick support can not be downloaded either for this device. Do I realy have to junk my ipad 4 which still works fine or is there an other solution?
thanks
I might be resurrecting an older thread, but I wanted to add some more info. I only recently updated TeamViewer on my work PC and that’s because it kept nagging me about an update (went from 12 to 14); and now I can't remote control it from my iPad because it won't let me install version 14 on my iPad 4. Sadly the TeamViewer server isn't smart enough to scale down features and receive connections from older versions of TeamViewer Remote Control.
I thought the issue was TeamViewer 14 didn't work with iOS10, but that's not right, it does, but only iOS 10 if it’s installed on devices that are also compatible with iOS 11 (think iPad Air and iPhone 5S era devices). Hopefully I'll be able to figure out how to downgrade TeamViewer on the PC, otherwise I'll be stuck and will have to either find another remote solution, or buy a new iPad {shudder}.
I'd like to make a plea for TeamViewer corp to allow the TeamViewer server to accept remore controlling sessions from older versions of the remote app... even in a limited capacity.
Exact same problem, says an update is available, then says icnompatible, but leaves it on the update list....annoying
The App Store is STILL showing me a notification that an upgrade is available, but it isn't as the upgrade version is incompatible.
how do we make this notification stop? I did ask this about a month ago but no response.
So how do I stop the App Store showing me a notification that an update is available?
Your answer doesn't seem to be correct. I have an iPad 4 on IOS 10.3.3 (latest) and the App Store says that v 14.0.141353 is incompatible with my device. However it (annoyingly) constantly shows a badge icon that an update is available.
Hi @Callsure
Thanks for your post.
For iOS we support the following:
Please check our Knowledge Base article here.
I hope this infomation helps you.
Best, Esther
Have you heard?! On October 21, we’re hosting TeamViewer Rise—and we want to see you there! The digital event dedicated to IT experts. Join us to hear industry leaders as they share demos, roadmaps, and real-world strategies for delivering better IT. Take part in our first annual event for Proven, ready-to-deploy…
