mouse-->android ok mouse-->android-->PC no!
fabredolo
fabredolo Posts: 7
Good morning
I use the mouse on my Android phone.
By connecting remotely with Windows Remote Desktop I can use the Android mouse on the remote PC.
Using Team Viewer instead, it is not possible: am I wrong or is it a possibility not yet present in your software?
    Hello fabredolo,
    The full remote control is only available with a certain number of manufacturers.
    You can check if your Android device is part of the compatibility list just here : Supported Android devices for full remote control
  • fabredolo
    maybe he did not understand the problem.
    I connected my mouse to my Wiko UFeel phone (Android 6.0). By connecting with the phone remotely to my PC, the mouse cursor on the phone is not recognized by Team Viewer.
    (If I use RD client instead I can do it)
