New user and connecting with freelancer to view work
Hi Community
Not used TeamViewer before and I've been asked to connect with a freelancer to view work that has been undertaken. Little concerned about the remote access elements and not completely sure how using TeamViewer works. Just want to be able to view the completed work remotely. Is that safe/ easy/ advised etc etc.
JeanK Posts: 3,018 Moderator
Hi Paul,
We have a great documentation about the use of TeamViewer.
You can find it on the following link : TeamViewer documentation
Feel also free to visit our Knowledge Base on the Community itself.
French Community Moderator5
