Teamviewer 13 Host Deployment
I am trying to deploy a configured host for my corporate PC's, this works on most machines by using the Teamviewer_Assignment.exe tool with my api etc. However on a few machines this REFUSES to go on. I have tried remaking this but no luck.
TeamViewer_Assignment (r350)
=> Assignment failed with:
POST-Request 'devices/assign' failed with 400 (API-Error: 'failed_to_assign_manager_to_device' (Code 17), Description: 'FailedToAssignManagerToDevice')
Any want help ?
I have these same problem
Hello Andrew94,
The mass deployment of the TeamViewer Host has changed.
Here the new instructions to do it :
I wish you a good day.
You're right, but the new solution is not working.
I use the received guide: https://community.teamviewer.com/t5/Knowledge-Base/Mass-deployment-improvements/ta-p/39639#toc-hId-**Please do not post TeamViewer IDs**I am trying to install TeamViewer_Host.msi (version 13.2)
I am using the command:
msiexec.exe /i TeamViewer_Host.msi /qn APITOKEN=<XXXXXXXXXX> ASSIGNMENTOPTIONS="--group KTW_komputery --grant-easy-access"
and a message appears (help msiexec)
if I leave ASSIGNMENTOPTIONS = then the installer starts.Where do I make a mistake?
Hello jlewicki,
I can see that you forgot to put the CUSTOMIDCONFIG in your command.
Please check in the edit window of your module (in the Management Console) the CONDIG-ID and add it to your command.
It should look like this :
msiexec.exe /i "<Path>\TeamViewer_Host.msi" /qn CUSTOMCONFIGID=YOURCONFIGID APITOKEN=YOURAPITOKEN ASSIGNMENTOPTIONS="--alias %COMPUTERNAME% --grant-easy-access"
timeout /t 5
net stop teamviewer
net start teamviewerI suggest you to remove the "group" command, because you can already define this in the module settings (in the Management Console).
Also, I recommend you to use --alias %COMPUTERNAME%, so the name of your computer shows up in your Management Console after the deployment.
It is also important to type in the command to stop and restart the TeamViewer service.
It should work fine.
If you need any further information, please let me know.
https://drive.google.com/file/d/1LldKptwU_tXwblSNpn2a7f7U-crE-m8S/view?usp=sharing
Unfortunately, it still does not work.
After pressing the "enter" button the following window appears0 -
Anybody can help me ?
Hello jlewcki,
Sorry for the late reply...
It does not work if you place the MSI on the desktop. Could you please test it again with placing the file in a regular folder on your computer ?
Thank you in advance for your reply.
Everything works fine without the ASSIGNMENTOPTIONS = "<YOUR_OPTIONS>" command
Hello jlewicki,
We are glad to hear, that you could fix your issue.
No! i don't fix my issue
I need use ASSIGNMENTOPTIONS = "<YOUR_OPTIONS>" command but if i used this then windows show me MSI popup
Hello jlewicki,
Thank you for your message and sorry for the misunderstanding.
Which options are you trying to execute ? --alias ? --grant-easy-access ? etc... ?
Try with --alias %computername% and other possible
Hey jlewicki
I succesfully installed the Host Module to all our users. But with a GPO that runs a powershell script that runs a bat file.
Dont know if this can help you in anyway but this is what I have used.
msiexec /i \\mylocation\TeamViewer_Host.msi /qn CUSTOMCONFIGID=xxxxxx APITOKEN=xxxxxxxxxxxxxx ASSIGNMENTOPTIONS="--grant-easy-access --group Teamviewer --alias %COMPUTERNAME% --reassign" IMPORTREGFILE=1
Regards Mark
