Can't connect to the other computer
macotochan
Posts: 1 ✭
When I try to connect to a remote computer I get a "unable to connect Reason unknown" error. both of these computers worked before. I already restarted both computer.
Any suggestions?
Thanks.
Dear @macotochan ,
Which operating systems do you use on both sides? If they are Windows devices, can you please try to restart the TeamViewer services on both sides and try to connect again afterwards?
NataschaGerman Community moderator 💙 Moderatorin der deutschsprachigen Community
