TeamViewer14 remote access
BWells502
I had received the message that TeamViewer thought I was using the program for commercial use. I was not. I am now able to again see my remote computer, but cannot see the cursor. Can someone give me **bleep**-proof instructions on what settings I need to confirm so that I can use the cursor on my remote computer.
Thank you.
Barbara
Hi Barbara,
can you check whether the following setting is enabled within your TeamViewer Software:
Extras --> Options --> Remote Control --> Show your partner´s cursor
Hope this helps.
Best, Esther
Former Community Manager
