Well it seems us lowly peasants are not permitted to use TV any longer. I was away on holiday and attempted to log into my pc at home to play a game as i have done for a long time and was met with the much hated "PAY US" window....
All my PC's are linked to my account and i only ever connect to them but alas this didnt stop TV killing all my pc's
Ok fine i sent off the request to reset and well.... nothing... it has been over 6 weeks and still no reply nothing. i am ultimately disappointed in the companies handling of it's userbase. if you want to cull free users then say so and move on. I have forthwith discontinued using TV at my business of which we do pay for it. It's stinks of underhanded money grab to me.
Letting everyone know that i doubt it's going to get any better and we should look for alternatives that have a little more professionalism
2 -
I've been using TeamViewer for a long time for personal purposes.
Two weeks ago I tried to make a call with a friend of mine in Dubai (I'm from Spain) and we had several cuts because connectivity there is horrible.
In the UAE the external connections are very often restricted, so we tried, we tried and finally we could talk for some minutes but after that, I started getting a message that TeamViewer detected a commercial usage and it lets me use it for 1 minute and it stops.
I'm using it to talk to friends I have all around the world, never used for commercial purposes.
Who can help me to fix this problem, please?.
What we don't know, and we can only guess (but it looks very much like this is the situation), this is not a bug, but a feature (i.e. they want, for an unknown reason (at least to us), to convert free users to an expensive license). If this is the case, then there is nothing much to hope for.
totally agree.
it is a subtle try to convert users.
switching to **Third Party Product** or **Third Party Product**.
bye bye TV
I finally got an email to say they've set my back to free - but that was before I found out I have to list all the IDs I use and connect to, so we'll see how I go on Saturday when I try to connect to my Mother overseas. I'm not very hopeful
That's very sad! ! I have similar situation and I've submitted the form since early Jan. I rec'd an email from TV saying my account will reset but in fact nothing changed with the "commercial use suspected" pump up. No hope!0
Did you try it? I tried mine for about 15 minutes today, it still gave the commercial warning at the beginning but it didn't kick me out and at the end it said free. I'll give it a proper test over the weekend with a different computer, we'll see if that makes it fall over
I'm using TV since a couple of year. Unfortunatly since a few week my connection stay open only 1 minute.
I understand that is happening because TV think it's a profesionnal use.
I made an email for explanation and I received an answer telling me that my ID was reset to free. But since this email nothing changed.
Do i have to change something? or wait more than 4 days?
Hi
it's my first time.
I'm a personal user with 2 pc (the first to control the second one). How to send a message to support to continue in the use of teamviewer that in this moment is suspende because I'm considered commercial user?
thanks and regards
morogroup
Are you sure nothing has changed? When I was notified, after a month, that my personal use status was restored, a nag screen still popped up saying I was suspected of commercial use. I didn't bother to go past that point for quite a while, but when I did, I found my usage had in fact been restored. The nasty nag screen still appears, but all is still working fine.0
Yes i have been trying every couple days since and sometimes i will get 1-2 minutes some times will not even connect. still no email from them about the reset i sent in december
I tried and I was disconnected in 1-2 minutes time... that's so sad!0
Thank you your reply. But I just use Teamviewer to transfer the files beetween my computers. There is no payment in my activities. What do I need to dp to prevent this case happening again? I can't complete my work beacuse of problem.
If you're just using TV to transfer files, it would be easier to use cloud services. Google has one, it's called Drive. You can configure it so that you use file manager to drop into a folder, and in less than a few minutes it appears in the corresponding folder of your destination computer. I am confident it works with MAC, too.
When I need to share files with linux devices (including Raspberry Pi), I use a network attached storage (NAS) Most newer routers will allow you to attach an external USB drive to it and the combination acts as an NAS. This latter is faster than cloud based services and can be used on to share files on all OS's.
Teamviewer is not responding. So I have to uninstall it? This is useless. I would have liked an answer before changing the product.
AFAIK, the file transfer speed was drastically limited for free users.
Incorrect choice of commercial use during installation, resulting in a trial period. How to restore the personal free version.
I have no problem with speed.
"Teamviever group" is not responding about my problem (Commercial use, but it' a private use)
@AriannaMicrochi : no one from TV will respond in this thread, you'll need to look at the 1st page, there's a link to a form you'll need to fill and wait for an eventual answer...
Yes, I have filled out the form. I'm waiting for an answer.
But if it must happen often, I'll change product.
hello my personnal account is locked because the system think that i am professional but i am not a professional i just use it to help my familly and friends a few times .
i would like to unclock my account.
best regards
Hi
I have the same problem.
It's simple:
Solution 1:
Buy a license
Solution 2:
Find the link to the form you need to fill out by going through this forum. Fill it out and send it in. Wait several weeks to several months for a response. The response may be "send in a signed affidavit that you are non-commercial" but you are not given where to send it. You cannot send it to customer support because you are not a paid subscriber, So attach the image to your reply to the "send an affidavit"
Sometime after that, again waiting weeks to months, if you're lucky, with notice or without, your account starts working again. Or not.
Solution 3:
Use another remote control program
every time i uninstall and download it keeps asking me to buy and my trail version already expire. The download says free for personal use which it is for my personal use but it’s not free. I keep looking at youtube on how to reset it but it got complicated. Is there an easier way?0
Solution 1: 27.90EUR/mo to help family??? NO!
Solution 2: yes. I've done. And now my account is again considered commercial.
Solution 3: [removed per Community Guidelines]0 -
@Stanislav : what's the TV official position on the ever growing thread of users being incorrectly accused of commercial usage (https://community.teamviewer.com/t5/TeamViewer-General/TeamViewer-thinks-I-m-using-the-software-commercially/td-p/8284) Thank you!
LE: I initially posted this for an upcoming AMA (Ask Me Anything) but it hasn't been accepted...
Hallo @Natascha @Esther @EstherH @Reyhan @Bernd @afabi ,
Ich warte nun schon seit mehr als 1 Monat auf eine Antwort bzw rückstellung meiner Lizenz!Ich möchte bitte endlich mal eine Stellungnnahme / Antwort!!
Ich habe über das Formular einen antrag gestellt und nichts ist geschehen!
Ich habe per E-mail kontakt aufgenommen , das Formular unterschieben und wurde aufs Forum verwiesen. Im Forum geht auch nichts weiter!
Ich habe postalisch und auch via Internet Schlichtungsstellen Kontakt aufgenommen ebenso ohne erfolg!
Was ist so schwer eine FEHL INSTALLATION MIT KOMMERZIELLER NUTZUNGS SPERRE RAUS ZU NEHMEN????
Ich bitte endlich um Stellungnnahme!!
2 -
Hello
I use Teamviewer every day privately and not commercially because on only one of my computers I have photoshop installed. Except that now I have an incessant pop up that tells me: Professional use
Commercial use has been detected and my session will be interrupted in 5 minutes.
I also got the following message:
Your license limits the maximum session time with a partner, immediate reconnections are blocked. Please try again later or upgrade your license0 -
I had the commercial version in the past but now i want to have the free version. Although i uninstalled team viewer (and the settings off the app) from my pc and installed the free version it didn't work. It does not allow me to connect with a partner, it still shows a message that i used the commercial. How can i get the free version (just for private usage) and get rid of the commercial? Thank you in advance.
