Hallo Natascha
Ich habe vor 4 Wochen das Formular ausfgeführt und verschickt. Bis jetzt noch nichts vernommen. Lästig ist aber die Herinnerungsmeldung, die jedesmal erscheint obwohl ich Teamviewer momentan nicht benütze. Kannst du mich einen Zeithorizont angeben wann das Problem gelöst wird?
Danke und mit freundlichen Grüssen
Ton
Hi, as you can see from my account, I have used Teamviewer Free in the past to support a local charity.
I now do voluntary unpaid work to support my local General Practitioners' Surgery (My Doctor).
I would like to use Teamviewer Free to help me in my work which includes updating the TV screen in the surgery showing images and videos promoting health.
Teamviewer Free assumed that I was using the service commercially, probably because it recognised the installation of SignageLive on the remote PC which is the well known service used for displaying information on screens.
Please will you allow me the use of Teamviewer free, because the surgery cannot afford the licence fee.Thanks, Geoff Hill
If this was the case it would be fine if they just told us "we can no longer support free users" and we'd move on but this facade they have is not doing them any favours.
I _was_ a paying customer until i was treated like this, i kept my private usage separate from my business usage in an effort to "do the right thing" but now, **bleep** it, i'll use something else.
Good luck finding something, I tried a couple and they were rubbish. I don't know what happens to good products, they either get 'updated' to death until they are unusable (like microsoft did to skype) or they just seem to let them rot like ICQ. Or they start a new program and promise it will be forever free but a few years down the track they keep it free but bury under stacks of advertising to upgrade and are forever trying to sneakily you get you to upgrade (avast), and it seems teamviewer is doing this
@Akala : funny thing, I wanted to post this, but you gave me the perfect opportunity by your message. Well, ICQ was the grandfather of all chat programs, I remember how it was the top back in 2001 2002, almos 20 years ago, but it faded, overtaken by different types of Messenger (Yahoo! etc.) Now it's Russian and nobody uses it, almost.
But back to my story: I've been a long time user of Piriform products, most notable CCleaner. Recently it was purchased by Avast
and I've upgraded to latest version yesterday. What do I notice? A nice message saying: This is free version not to be used in commercial environment
or something similar
and I was thinking come on not you as well!
ahh drat, I use ccleaner as well but haven't updated in the past week or two, but it is definitely becoming a habit
It happened to lots of graphics programs too, I guess I'm just too old remembering all this stuff. But if you can't predict the future just say you'll keep it free for as long as possible, dont make promises you can't, or don't intend, to keep. Even though my teamviewer was fixed, I don't have a lot of confidence when I try it on some of my mother's other computers. Oh well, one battle at a time
I use TeamViewer to connect from my mobile to my personal pc and for a while it tells me that it has detected that I am using it commercially.
On occasion I have connected to other equipment, but not for commercial use ....
What can I do to solve it?
Same here!
Team Viewer recently (a few weeks ago) suspected commercial use althought I changed nothing in my habits for years (same family/friends!).
And yesterday, I got the CCleaner pop up as well!
My home PC is a second hand DELL with Windows 10 Pro. Could it be a windows update that makes those softwares thinks I'm on a pro machine (server signature or something ?)
@pjgfi : no I don't think Microsoft would mess up with installed software in such a way (i.e. the displayed pop-ups clearly come from the applications itself). Moreover I got the CCleaner pop-up on other older versions of Windows as well (at least version 7).
For me it's just a coincidence but it made me grin, and I was thinking how did Piriform came up with the same wording as TV?
Thank you for playing fair! We do play fair, TV, we always did, but you seem to no longer play by your own rules.
Hi pv7721,
I know the popup come from the software itself but I thought it could have been a (new?) windows "feature" that software could check to tell whether they're running in a pro or home environment.
Did you get popup from both tools (TV & CC) on all your machines?0 -
@pjgfi : sorry, on Windows 7 I get warnings from both CC and TV, and recently I also saw some updates on Windows 7 but they were some preview versions of .NET Framework (anyways, Windows 7 is almost EOL so they won't update with feature).
However, I don't have the CC warning on Windows XP, which makes me think the following: all my Windows versions are PRO versions (i.e. I always preferred to pay a little extra in order not to have the Home version (which lacks RDP for instance)).
But if both software include in their check that the Windows version is a Pro version, then this is extremly dumb, nothing prevents me if I want to pay for it to use a Pro version as a non-professional user.
Hallo Ton,
vielen Dank für deine Nachricht.
Du kannst in den Einstellungen unter Extras --> Optionen --> Allgemein --> TeamViewer mit Windows starten ausschalten. Dann kommt die Erinnerung nur, wenn du TeamViewer manuell startest.
Bitte hab noch ein klein wenig Geduld. Solltest Du in der nächsten Woche nichts hören, würde ich dich bitten, das Formular einmal erneut auszufüllen.
Herzlichen Dank im Voraus und entschuldige die Unannehmlichkeiten.
Viele Grüße und einen schönen Mittwoch
NataschaGerman Community moderator 💙 Moderatorin der deutschsprachigen Community
Frome some days, I have a time limit to connect me to another PC, how I can solve this problem that I never had since years I use privatly the program.
I can not connect being particular , i am user spanish, since my mac it remained open tabsand he tells me commercial use not being that way, I only made a connection to another computer ina sporadic way. Please request solutio to continue being particular . Thak you. Yolanda cedillo. **Please do not post TeamViewer IDs**
Warum wird mein anliegen ignoriert????1
Hello everyone. I have been using TeamViewer for years now and have stumbled upon an issue on one of my computers. I am a personal user, only using the program to monitor and remotely complete tasks on my various machines. However, one of my machines has said my trial version expired. I found the other article about how to switch from commercial to personal, but all the links to verify your personal use are broken and lead to an ERROR-404 page. Is there anyone who can help me in this by providing corrected links or share what I need to to? Thanks in advance!
Hello @stargateguy1
I was able to verify this as well.
I have forwarded the issue to the appropriate team so we may resolve this as quick as possible.
We apologize for any inconvenience.
Josh P.
Senior Community Moderator---
I never received such a "commercial usage" message, but anyway tv (version 12) said "time out" after 5 minutes.
Thank you for your assistance, @JoshP When might I expect a solution to appear? No huge rush- I’m just trying to stay on top of things. Thanks! Glad it wasn’t just me!0
Hello @stargateguy1
Thanks for the feedback.
While I do not have a timeframe for resolution, I will reply here once resolved so you may verify it works again!
Our team is actively working on getting the resolution as we speak
Josh P.
I have same problem, today teamviewer let me connect only for 5 minutes but is not commercial use of application, why? can do for resolve taht issue?
This link should give the form, but it gives 404 error. I submitted the form a while ago and did not get any response. Maybe the form URL is changed? If so please publish the link.
Help, help, help.
I wonder if this is what's causing the commercial use issue with one of my laptops. @JoshP I have gone through the reset request form and not been reset, nor provided the decloration to fill out. Is TV having a problem with the resets? It's only on one of my eight devices, but I can't reach the other seven (in the same house) from the one being blocked.
I had a message that it was suspected I was using Teamviewer commercially and responded that it was only private use. On 23 Feb I received an email that said:
Thank you for getting in touch with us. We are happy to inform you that your TeamViewer ID has been reset to “free”. After reviewing your request, we decided that your use case can be qualified as “personal”.
I did not try until today to use it, but I receive the same commercial message. If I click OK I get a password window to log into the remote computer. Enter the password, and I see the remote computer but it logs me out in about 10 seconds. I am then blocked for 10 or 15 minutes. I don't seem to be able to contact Teamviewer direct so what do I do?
Hallo Martin,
vielen Dank für deine Rückmeldung.
Wir sind uns der Verwirrtheit unserer Nutzer bewusst, die davon überzeugt sind, dass sie TeamViewer nicht geschäftlich nutzen. Wir gehen jedem Fall nach und werden auch dein Gerät (TeamViewer ID) freischalten, wenn dies irrtümlich eingeschränkt wurde.
Mach bitte in deiner Anfrage konkrete Angaben, damit wir dein Nutzungsverhalten verstehen. Kontaktiere uns bitte nicht mehrmals mit derselben TeamViewer ID – sobald du deine Anfrage abgeschickt hast, wird diese bearbeitet. Bitte beachte, dass wir die Anträge in der Reihenfolge ihres Eingangs bearbeiten, die ältesten zuerst. Wenn du uns erneut eine E-Mail sendest, beginnt die Bearbeitungsdauer von Neuem. Bitte denke daran, das Formular in Englisch auszufüllen.
Du kannst sicher sein, dass wir alle an uns gestellten Anfragen bearbeiten. Aufgrund der großen Anzahl an Anfragen kann die Beantwortung etwas Zeit in Anspruch nehmen.
Bitte prüfe, ob sich unsere E-Mail in deinem Spam-/Junkordner befindet, wenn du nicht innerhalb einer Woche von uns gehört hast.
Herzlichen Dank für deine Geduld und einen schönen Donnerstag.
Viele Grüße
Error 404
@marcgalmes wrote:https://www.teamviewer.com/en/support/commercial-use-suspected/
Maybe it's a good sign that there's currently something wrong with the detection and they're updating the page...
EDIT : no, page is back...
Ich habe das gleiche Problem. Wenn ich den Link zum Formular zur Beschreibung der Nutzung anklicke, bekomme ich immer eine Fehlermeldung. Offensichtlich hat Teamviewer etwas losgetreten, was sie nun nichtbewältigen können. Herzlichen Glückwunsch! Sehr unprofessionell!
1
