Re: Enable Multiple Monitors using Policy
Yuri_T
Posts: 2,256 [Former Staff]
Hi @NigeNZ ,
Unfortunately we do not have the policy for the feature.
However, you can setup manually in Computers & Contacts.
- Select a device you would like to set up.
- Click the cog mark on the right top corner.
Click Properties
Click Advanced.
- Select your preference in a Initial screen tab.
Hope this will be helpful.
Yuri
Hi There
I am working with a test deployment everything is working well however whenever I connect it defaults to the users first monitor. This appears to be driven from the user side as setting it to multiple does not persist on subsequent connections or connections to different ID's.
I thought there would be a policy enabling this but that does not seem to be the case, can anyone point me in the right direction?
