Upgrade to Version 14 from Version 13 - install hang
Keith82
Keith82 Posts: 2
WIN 7 - not sure of level
Version 13 was installed and ruinning well.  Got update msg, version 14 available.  V 14 on other PC's Win 7 & 10.
Downloaded V 14.  Install hang.
Deleted V 13 from system via control panel.  Install again....same hang.
Tried again - let set in install for overnight.  Still hang.  Task Manager says 'not responding'.  Had to kill install.
I would appreciate any help.
I am downloading V 13 again to try to re-install.
  • jasby
    jasby Posts: 1
    I am having the same problem right now.  I even uninstalled V12 and that did not help.  Running Windows 10 and also installed latest IE as suggested.
  • Keith82
    Keith82 Posts: 2
    After the version 13 reinstall, I deleted it and version 14 installed with no problem. That's what I remember
