Silent Installation of Teamviewer with Licence Key
Hi
we are using teamviewer corporate licence and we deploy all applications by microsoft sccm.
How can i deploy teamviewer full client msi (not host!) with licence key?
importing or adding the licence manually after installation is a bad idea with 1000 clients.
Install TeamViewer Full on a test client, get the installation options exactly how you want, then on one of the last configuration sections in the TeamViewer client, it allows you to export your settings to a reg file. It MUST be named "Teamviewer_Settings.reg". You'll also be able to add your license info DURING the export process.
Once you have the reg file above, place it alongside the MSI installer for TeamViewer. When executed, the MSI file will read your settings from the REG file and viola! I've done this on thousands of systems via SCCM.
what exactly means "license info" during export to Teamviewer_Settings.reg? Its the corporate -license id (does'nt work for me). its a token i can see into management console?
