TeamViewer main window is not maximized on startup
Hi, I have a problem with Windows TeamViewer application. Everytime I start the app, the main window (with list of computers etc.) doesn't remember its last state, ie. it doesn't start maximized. I have to manually click the maximize button. I am using the "New UI" which can be set via the Options menu. What can be done to prevent such behavior?
  • olivierkeysers
    I'm having this issue as well. It partially apears on my second desktop every time I reboot or login. It's annoying!
  • Modarelli
    Modarelli Posts: 1
    Has this issue ever been addressed? This is very annoying to have to Maximize the window EVERY time I start it up.
  • .Carol.fg.
    .Carol.fg. Posts: 1,083 Moderator
    Hello @Modarelli ,
    Thank you for your question and welcome to the TeamViewer Community!
    Are you using Windows OS?
    If you are, did you check the settings for Startup Apps already?
    I hope this can help 🍀
    Let me know if you need further assistance. 😊
    Carol
