Permanent Password - Never asks for it
poetsstudy
Connections don't ask for personal permanent password for unattended access. It just lets you connect without asking. It's also not set up for "grant (user) easy access". What am I doing wrong? It used to work.
Well I just figured it out. Go figure. If I change the password to something else it finally works. Now I can go back and change it to the normal password.
