Desktop login LAN—Email field inaccessible
Trying latest free downloaded & installed TV, configured on both local PCs for LAN only Accept Exclusively—"Only LAN connections are possible" shows at bottom of main dialog beside small round green icon.
I click the Partner ID dropdown & click 'Show nearby contacts and devices', and get a login dialog "Sign in using your Teamviewer account" with Email & Password fields. That's where the problem is.
I can type my password no problem, but I can't type in the Email field or give it focus—it's just dead, same as other dead non-field parts of the dialog.
My email address is activated with TV.
Is there some setting I need to change, or do I have to use remote access via internet as a workaround?
Thanks.
  • errik
    errik Posts: 1
    how the solution ? the same problem with me, email field disabled.
    so I cant login
    please the solution
  • Ying_Q
    Ying_Q Posts: 2,598 Moderator
    Hi @errik
    Can you kindly check is your TeamViewer connected with internet and also TeamViewer is online please?
    Community Moderator/中文社区管理员
  • brucewol
    brucewol Posts: 6 ✭✭
    I have the same problem. Although I want lan only connections for TV, the pc connectd to the internet. doing this post right now on my problem pc. On another pc, I have logged on, so that appears as online. but on this pc, i can't login so how would i get it to be online.
