TV14 discard new random password
I want to connect with an other computer, but if I type the correct password, the other Teamviewer changed automatic the password and I become refused. If I type the new password, it will accept.
Both computer use openSUSE 15.0 64 bit, with Teamviewer 14.1.3399
I have make a video, to show this issue:
https://www.youtube.com/watch?v=QcQThg3tPZg
  • AlenaC
    AlenaC Posts: 932 Moderator
    Hi @Schwarte ,
    thank you for your post. Could you please try to update your TV 14.1 to 14.2?
    Have a look at this link, if you need more information about how to update your TV (Updating to the latest and greatest version of TeamViewer. ).
    Please let me know if I can assist you with more information.
    Looking forward your answer, have a nice and hopefully sunny day!
    Alena ;)
  • Schwarte
    Schwarte Posts: 4
    Hello @AlenaC
    thank you for your quickly answer :)
    I had update both TV installations to the version 14.2.2558, but they have the same behavior. :(
    I tested it a bit more and every time I try it, I can use the passwort "mkw257" (without quotation marks). Never mind, what password TV show me. But I have not set a personal passwort (for unattendet access) in the options. So, I tested it in the other "direction" and it works fine (accept the displayed password). I had delete the cache-folder (~/cache/TeamViewer) and the config-folder (~/config/teamviewer) on the target computer (which can acessed with mkw257), but no change.
    Here are the log-files from ~/.local/share/teamviewer14/logfiles:
    Source computer (without problems): https://pastebin.com/T6sg6gf7
    target computer (with mkw257 access): https://pastebin.com/x27V2vTi
    In the target log file, TV14 says sometimes:
    ResourceLoader: loaded file '/opt/teamviewer/tv_bin/resources/TVResource_de.so' version (2558) is not matching with application version (14.2.2558), Errorcode=2
    But on this computer, only one version of Teamviewer is installed:
    zypper se -s teamviewer
    Repository-Daten werden geladen...
    Installierte Pakete werden gelesen...
    S | Name | Typ | Version | Arch | Repository
    | teamviewer | Paket | 14.1.3399-0 | x86_64 | TeamViewer - x86_64
    | teamviewer | Paket | 14.0.14470-0 | x86_64 | TeamViewer - x86_64
    | teamviewer | Paket | 13.2.26559-0 | x86_64 | TeamViewer - x86_64
    | teamviewer | Paket | 13.2.13582-0 | x86_64 | TeamViewer - x86_64
    | teamviewer | Paket | 13.1.8286-0 | x86_64 | TeamViewer - x86_64
    | teamviewer-host | Paket | 14.1.3399-0 | x86_64 | TeamViewer - x86_64
    | teamviewer-host | Paket | 14.0.14470-0 | x86_64 | TeamViewer - x86_64
    | teamviewer-host | Paket | 13.2.26559-0 | x86_64 | TeamViewer - x86_64
    | teamviewer-host | Paket | 13.2.13582-0 | x86_64 | TeamViewer - x86_64
    | teamviewer-host | Paket | 12.1.83885-0 | x86_64 | TeamViewer - x86_64
    | teamviewer-host-suse | Paket | 14.1.3399-0 | x86_64 | TeamViewer - x86_64
    | teamviewer-host-suse | Paket | 14.0.14470-0 | x86_64 | TeamViewer - x86_64
    | teamviewer-host-suse | Paket | 13.2.26559-0 | x86_64 | TeamViewer - x86_64
    | teamviewer-host-suse | Paket | 13.2.13582-0 | x86_64 | TeamViewer - x86_64
    i+ | teamviewer-suse | Paket | 14.2.2558-0 | x86_64 | (Systempakete)
    v | teamviewer-suse | Paket | 14.1.3399-0 | x86_64 | TeamViewer - x86_64
    v | teamviewer-suse | Paket | 14.0.14470-0 | x86_64 | TeamViewer - x86_64
    v | teamviewer-suse | Paket | 13.2.26559-0 | x86_64 | TeamViewer - x86_64
    v | teamviewer-suse | Paket | 13.2.13582-0 | x86_64 | TeamViewer - x86_64
    v | teamviewer-suse | Paket | 13.1.8286-0 | x86_64 | TeamViewer - x86_64
  • Schwarte
    Schwarte Posts: 4
  • Schwarte
    Schwarte Posts: 4
