Still problems connecting to teamviewer server
I can reach the masterservers on all three ports (80, 443, 5938), but I cannot connect to any of our PCs.
I get an errorcode of 10054 in the log.
Any suggestions?
Since yesterday it seems to work again.
I have no clue, what was the problem, as there was no DNS or general Network Problem.
From our Network not even all Teamviewer 10 Version were affected. There is one, that never had a problem.
I can only guess, that it was related to teamviewers move to a new datacenter.
I'm glad it's over now.6
The same problem.
look at www.rbls.org.
the ip 185.188.32.1 is listed in Blacklist
I'm on Team Viewer 9.
I haven't been able to connect to the server for nearly 24 hours now. It comes up with the 'Most likely you use a proxy server' message. It was running fine yesterday afternoon and I've used it every day for years now. Same computer, same setup, same connection. No changes at my end. What's going on? Did you bungle the maintenance you did on Sunday?0 -
Is this the Problem ?
DNSBL checking the result of IP 185.188.32.1.
rDNS found:
- <master1.teamviewer.com> valid FCrDNS.
This IP has been blocked, but it's reputation is not bad anymore.
I have a Tracert from different places.
All stop at address 217.146.20.18
Please contact ANEXIA Internetdienstleistungs GmbH in Austria for routing problems0 -
@JoSte wrote:look at www.rbls.org.
Hi @JoSte,
Thanks for pointing that out - but no, that's definitely not related to the connection issues being discussed here. DNSBLs are used by some mail servers as a means to block spam from disreputable sources, and being listed on one - in this case, a small, not-widely-used BL based in Brazil - would have no effect on the ability of the TeamViewer software to connect to our master servers.
Jeremy
TeamViewer Quality Assurance Engineer1 -
Hey Jeremy, you may want this in another thread but i am having a similar issue. I use my computer in the field a lot and when i come back teamviewer wont reconnect. I have internet and other computers on the network using team viewer. it come up with the no connection check proxy server box every 30 seconds. can you help me get connected please. Thanks
