I'm using Fedora Linux, and successfully installed teamviewer_11.0.67687.i686.rpm. But I'm getting a dialog "No connection to TeamViewer server. Please check your internet connection. Most likely you use a proxy server and you have to enter the proper information in the options dialog."
$ sudo systemctl status teamviewerd.service
[sudo] password for chris:
● teamviewerd.service - TeamViewer remote control daemon
Loaded: loaded (/etc/systemd/system/teamviewerd.service; enabled; vendor preset: disabled)
Active: active (running) since Sat 2016-11-12 13:08:18 PST; 18min ago
Main PID: 4751 (teamviewerd)
Tasks: 14 (limit: 4915)
CGroup: /system.slice/teamviewerd.service
└─4751 /opt/teamviewer/tv_bin/teamviewerd -d
Nov 12 13:08:18 f25h.localdomain systemd[1]: Starting TeamViewer remote control daemon...
Nov 12 13:08:18 f25h.localdomain systemd[1]: teamviewerd.service: PID file /var/run/teamviewerd.pid not readable (yet?) after start: No such
Nov 12 13:08:18 f25h.localdomain systemd[1]: Started TeamViewer remote control daemon.
I've also stopped firewalld just to test if it's the firewall. And there are no SELinux AVC messages. So I can't figure out why it can't connect to TeamViewer servers. On a Mac, on this same wireless network, I don't have this problem.
