Teamviewer ServerID and password on VM
NOUVEM_Support
Posts: 2 ✭✭
When I RDP to a VM and set teamviewer up, I get a UserID and Password as I would expect. However, I need the serverID and password so that I can teamviewer in even when no user is logged on. I can get the ServerID is help - about but I cant find the password anywhere.
Help!
Issue solved - The same unattended access password works for both UserID and ServerID. When ServerID is used, login is possible without user logged in
5
5 -
When I connect to my WinSRV2016 VM hosted on GoogleCloudPlatform I only get a black screen and no commands works
Thanks,
Best Regards,
