Once a week (Sunday morning), when I start Windows 10, right after the desktop appears I get a popup asking me to open a txt file.  The file is in C:\Users and is simply named john.txt.  The contents of the file is:
C:\Users\John Blaustein\AppData\Local\Temp\invF7BA_tmp Blaustein\AppData\Local\Temp\invF7BA_tmp\icinitlog.txt
If I do nothing and reboot, the same popup appears.  If I delete the file from C:\Users, the popup is gone, but only for one week.  Then it appears again and the file is there again.  When I look in AppData, I can't find the file.
Is this file related to TeamView?  If so, is there a way to stop the popup from appearing once a week?
Thank you for any help with this.
John
