The Teamviewer "Add-On: Samsung" wont install on Samsung Galaxy S10+. Works great on Samsung Galaxy S8.
I belive Teamviewer needs to publish an updated version on Google Play Store.
The addon and a new update for the app will be available in the Playstore within the next hours - please do not download the beta addon anymore!
Both - the addon and the app - need to be updated.
Cheers,
i joined the telegram room, there are no apks and not available to chat, can you post the apks in there please for teamviewer host for note 9 that don't use knox?
I got a note 9 and I downloaded teamviewer host, teamviewer for remote support, and teamviewer quick support. None seem to work, stays forever on login for teamviewer host, quicksupport is forever on activating id?
Can someone please reupload the beta versions that dont use knox? I really need to get teamviewer host working
Thanks!
I have faced the same issue as not able to install Add on Samsung with model of Samsung Tab A8 T295.
Hopefully teamviewer technical team can help me solve it, I need to access this device for work.
Thank
I could not install Add on Samsung for Android 9 devices (SamSung tablet T295)
Anyone help me this case? (( I really need for install it
Dear Julia, I have reviewed the version of the Add on of team viewer for samsung and it is the same version. When trying to connect to a device it tells me that the add-on is obsolete, since it is the latest version.
I wait your answer.
regards, Claudio
Can confirm this works on my A70.
you have to reinstall both the add-on AND the quicksupport app itself
Thanks Julia!!
I have tried it several times... i cant download it, can you upload to other site? google drive, mega, etc
The link is broken, can you upload to other site?
can you upload the apk please?
Can you upload the apk again? the link is broken.
I am configuring 700 new Samsung mobile and I need it!! Thank you!
I cannot install on my Samsung Note 9, just fails with Can't install Add-On: Samsing
Appears to be a linux issue: I downloaded/installed Teamviewer on an old Win7 box and it works for both of my devicesS4 & S10Are you aware of the Linux issue and is there a work-around?
I have TeamViewer, QuickSupport and the addon from url installed on my phoneI have TeamViewer installed on my Linux BoxStart QuickSupport on the phone, and TeamViewer on the Linux Boxinsert the ID from the phone on the TeamViewer Partner IDRemote Control selectedSelect Connect, Authenticating ...On the Phone: Allow remote Support: AllowTeamviewer indicates Authentication AcceptedPhone spins for a while ...Both go back to original screenReady to connect(secure connection) displayed on bothTried the same installs on my old S4, same result. Does this work on linux?
Ok, I downloaded apk from url above. Then clicked on it and allowed install If I goto downloads and attempt to install it again, says already installedHowever, when I open TeamViewer it still says I need to install Quicksupport to allow Remote Control. This seems like a catch 22, what is the correst order of operation?
New to Teamviewer and just got my S10 yesterday.
What needs to be installed on the phone prior to this apk?How are you suggesting the install of this add-on apk?
I downloaded apk to my linux box and attempted to load it via appium, but it fails
BTW: My pc is running linux Ubuntu 16.04 with TeamViewer: 14.2.8352, FREEThanks!
It's a general problem with Android 9 on samsung and the update is not yet published on playstore. Click here in order to download the updated apk that works with Samsung android 9. Enjoy!
Is there any indication of when this add-on is likely to be published to the Play Store? We are currently unable to supersede our existing installation as that the beta version shares the same version code 3086.
I'm attempting to install and configure QuickSupport on the first of a few work phones - Samsung Galaxy A70 - but the mandatory QuickSupport Add-on refuses to install after download - rendering remote support on the phone impossible.
What's the solution here?
I have tried it and so far it works well
It seems to not play well when minimized (i mean, it IS the Host app, it should work all the time) but I will continue playing with it, maybe it is my fault.
I have a Samsung Galaxy S10+, Android 9, by the way.
[Expired link removed per Community Guidelines]
the link doesn't work
Thx for finally addressing this. It works!
Update the link, please!
in android 9 Samsung J6 devices Quick support add on is not getting installed. plz help.
Hi, the link has expired. Please, could you provide it again? I'll be thankfull.
King regards.
