api/v1/meetings gives Error 500
When trying to use the api call api/v1/meetings I get error 500 if I use ping or if I add
a scheduled meeting Id at the end it works fine.
What can be wrong is it the api or should I do this another way?
  • BjarkePetersen
    Hi FredrikN,
    Did the problem resolve itself?
    I'm getting the http 500 error today with the POST /api/v1/users (create user) but not with the GET /api/v1/users ...
    Did not get the error yesterday.
    http error 500: Internal Server Error: Some (unexpected) error on the server. The same request should work if the server works as intended.
  • FredrikN
    FredrikN Posts: 12 ✭✭
    No it didn't the case is it's sent to Teamviewer developers to investigate.
    I haven't tried create user but I will probably soon, will respond to this post when I do and what the result is.
  • AlenaC
    AlenaC Posts: 932 Moderator
    Hi @FredrikN , @BjarkePetersen ,
    as @FredrikN already suggested, if you have a license, could you please send us a ticket?
    Thank you in advance,
    Regards, Alena
  • BjarkePetersen
    Hi @AlenaC ,
    We do have a license - I raised a ticket with support yesterday.
    Haven't heard anything yet (except for the ticket created confirmation email)
  • BjarkePetersen
    Hi @FredrikN ,
    In my case I got the HTTP 500 error when attempting to create a user because:
    "The email address is already in use"
    Would have expected a 422....
  • tejendra_pratap
    tejendra_pratap Posts: 2 ✭✭
    @FredrikN @BjarkePetersen Can you please tell me how to get Authorization token, as it says "Authorization header missing" on Post call to create instant meeting.
