Timing out inactive sessions not working - Disconnects after 4 hours
The timing out of inactive sessions-function isn't working.  It's set for 8 hours but always disconnects after 4 hours. What might be the problem?
Thanks on beforehand!
  • Ying_Q
    Ying_Q Posts: 2,592 Moderator
    Hi @mrscheng ,
    Thankyou for your post.
    Can you kindly provide the information of TeamViewer versions and operation systems from two sides of the connection please.
    Community Moderator/中文社区管理员
  • mrscheng
    mrscheng Posts: 4
    OS is win10, TV version 14.2.8352 on both comps
  • mrscheng
    mrscheng Posts: 4
    bump =)
  • mrscheng
    mrscheng Posts: 4
    Hello! I replied to your question but haven't heard from you in a while.
    The specifications are mentioned in the post above.
