I am posting here because this issue does not occur from my Windows machine on the same LAN.
When I use Ubuntu to connect to my Android device (all on the same LAN), both sides show the connection being made.  After the connection negotation, the Android device shows that I'm connected ("connected to kevin"), but no control window appears on Ubuntu.  Then, after about 5 seconds, the connection closes, and it just shows that I'm ready to connect again.
Here's the last part of the log:
*Logs Removed by Moderator*
Let me know if more of the log is needed.
I've also tried using my mobile data connection instead of wifi on the Android device - same result.
This is Ubuntu 16.04 running TeamViewer 13.0.6634.  Android device is ZTE Axon 7 running TeamViewer Host and QuickSupport 13.0.7847.  I also have the ZTE plugin for TeamViewer.
Any ideas?
PS:  I can connect from Ubuntu to Windows without issue.
