No connection to TeamViewer server
where can i setup so that the section where it says Windows Logon, i would like that option to be set to Allowed for Administrators Only.
Hello @dnunez1939
In order to set up this locally, please go to Extras → Options → Security and you will be able to select Allowed for administrators only in the parameter Windows logon:
You can also enforce this parameter via settings policy. Please select the settings policy Windows logon and set it up as in the following screenshot:
You will find all the information you need to add a policy setting in our Knowledge Base article here: How to add a new settings policy
At the bottom of the article, the Windows logon is also explained.
I have tried this, added the policy to my Host configuration. Re-downloaded the .exe the msi but this policy never applies.
what else can I try to get this to work? The Code works just fine, but each time I try to change to windows auth it says the user has disabled windows login. So the policy is NOT applying.
thanks in advance.
