TeamViewer session disconnect on sleep
Does an open TeamViewer session get automatically disconnected if I put my machine to sleep?
Or, more explicitly, if I am connected to another machine using TeamViewer, will putting my machine to sleep automatically end the session and release the session token?
    Hello @jeremymorgan,
    Yes, it is normal that when your master machine goes into sleep mode, the remote session stops. There is, unfortunately, no official work-around for this.
  • eb123
    eb123 Posts: 1
    Is this still the case? Or is there an official workaround for this?
