teamviewer version 8 windows2000
Johanfit80
Posts: 1 ✭
I Have an windows2000 pc with teamviewer version 8 which i would like to take over from another PC. It was already working, but now is says that the version is to old on the windows2000 machine. But version 8 is the latest version which can work on a windows2000 system.
Does anyone has a solution for my problem?
With kind regards,
Johan Fit
I have the same problème. It sems nobody works on a Win 2k ! And Teamviewer support manager has no time to find a solution !
Best regards
Louis0
