Password to acces the options
Ypres
Ypres Posts: 1
Dear,
I want to see what the optoins are in the new 13 version. But I need a password and it seems it's not my password that I use to login on my TV account.. Anybody an idea?
  • Bragon
    I have got the same problem
    No avalaible password to have acces option.
    My account is well recognize
    Which password we have to use to acces option ??
    Kind regards
  • Julia
    Thank you for your posts!
    If you cannot remember the password for the options you have to uninstall TeamViewer with all options. To do that, please go to "Programs & Features" choose TeamViewer and click "uninstall". You have the option to choose "uninstall with all settings" during the uninstall process.
    Cheers,
    Julia
  • Bragon
    Bragon Posts: 3
    Dear Julia,
    I found finaly my password :)
  • Montclair
    Montclair Posts: 2
    1. Exit TeamViewer. Run --> regedit.exe
    2. Browse to --> "HKLM\Software\WOW6432Node\TeamViewer" folder.
    (depending on your version, you might a sub-folder called "Version X").
    3. Select --> "OptionPasswordAES" key
    4. Right-click on that key and select the "Delete" option. Confirm the deletion and close the registry editor.
    5. Restart Teamviewer. The Options no longer require a password. Now you can set it again to whatever you want.
  • Doiron111
    Doiron111 Posts: 2
    Thanks for sharing this steps, steps help me to recover my account.
  • JARCDSS
    This is the biggest issue in teamviewer ,  time time the password for options doesn't work
    at the same time the password to access the pc from  another location , same issue
  • JARCDSS
    that it doesn't help,, everybody can do that.. the issue we have to do all over again,, and that issue still in Teamviewer
    It is a glitch, mostly is when is an update or upgrade
This Week's Leaders
