Version out-of-date: Update the remote Teamviewer
Same thing happened here. since today.
I cant access remote computer. I cant update it either.
Maybe its time to look for alternatives.
5 -
on the same network you should be able to connect to the TV IP address ( if incoming LAN connections are allowed in the settings ). As far as I realized from previous posts, this should work ...
Can t connect to my remote computer that is running version 12..... Please, we need a fix, so we can update our clients to version 14. Cant update teamviewer remotely
3 -
Thanks all for continuing the discussion. I want to give an update from my previous post and explain how I was able to connect my other computer on the same network NOT by initiating a connection through the Remote Control menu (entering the partner ID and then clicking on connect) BUT by first going into the Computers & Contact menu and assigning my other computer to my account. To do this, I had to
1. enter my ID and password on my second computer,
2. on the gear icon at top right corner click on assign to account.
3. then from computer 1 I entetered the ID and password of computer 2 and was able to connect.
You should NOTICE that there the ID numer starts with a 1 followed by 9 digits but this 1 is NOT part of the ID, which can be very confusing and I was able to find out after hours of trying to troubleshoot. Your ID should only be the last nine digits of your ID.
Hope this helps.
2 -
HI, I have the same problem. I have two machines both running Team viewer 14 and I'm not able to have a connection. How can I solve?
Its a shame the no one from the team provide a solution for this serious problem until now...0
I am a paying customer, i have bought version 11 Premium, and i can tell you that they will not fixed anything because is not a "problem" for them, is a consequence from a commercial decision that they have made to get more money, that's all. A bad one in my opinion..
They have changed the limitations on the Free Version, they do not let free users to connect to computers with older versions, if you do not have a license you can only can connect to a computer that has the last version.
I have open a ticket with Teamviewer support and this was their answer:
"It is not possible to use older version of TeamViewer without a license, if you connect to them using your version 11 license you will be able to do it, but if they don't have a license they are not going to be able to establish the connection"
I am not guessing about the source of the inconvenience, what i really do not know is to whom they are aiming to get more money, the current customers?, the free customers? (they can download the free version and install it again, but... what will happend when they change to version 15 the next year?, all 14 version will be "older versions" and again the free customers will not be able to connect.
I think they do not care about customer relationship anymore.
Hope this help for the one that are waiting some fix that will never arrive
Best regards
4 -
This is quite disturbing. I have a paid commerical PERPETUAL license for Teamview 12. I paid to upgrade to 12 from version 9. I and many other owners of version 12 chose not to go with the subscription license for version 13 and cannot legally upgrade to 13. Last week, everything worked fine. This week, I can't connect to anything. What has Teamviewer done to disable connections to older versions? This needs to be corrected immediately.
3 -
Hi @wroshon ,
If you have a perpetual license for an older version, please make sure that you are using your license for these connections and if you still have problems, please contact our support team.
YuriCommunity Moderator/ コミュニティモデレーター0 -
Hi @roony94 ,
have you tried to set up a policy in the management console?
Please read: How to add a new settings policyHope this helps. Let me know if I can assist you with more information
Best, Alena
Alena C
Spanish Community Moderator1 -
I'm running newest version on both pc's, v14.3.4730. Am being told that I can't connect since the pc I'm connecting to is running an older version of TeamViewer. Not sure how that's possible, but it refuses to connect for that reason. If I use the remote version from the store, it loads immediately. Why won't the full version run when the Store app will?
And I am 3.300 km away, so no update posibble.
Maybe its time to look for alternatives. :-(
What bug was introduced by Microsoft to create this problem on previously wokring TVs?
It should not be necessary to install the latest version, unless Microsoft created this bug intentionally to force everybody to update to a "backdoor version" of TV. Am I correct?
I agree. This is Microsoft strategy. Either that, or their programming team is not very good at programming. Sorry, but it is true. Not everybody can program code.
The "version out of date" message is a joke. To test this, I used an older version to try to connect to a newer version, and still got the "out of date" message. How can an old version (written before the new version), legitimatley claim that the new version is out of date?
This sure looks like a Microsoft "scam" of sorts to me.
Let's all look for another solution instead of using TeamViewer, and then let's all cancel any subscriptions that we may have with TeamViewer.
Hello @GarryAnderson,
Considering that Microsoft created intentionally a bug in order to influence which version of TeamViewer people are using is extremely unlikely. This would be pure speculation and we do not support this
We always stick to the facts and try to act accordingly. We noticed through the feedback of many users that this kind of bug exists at the moment and that updating the versions to the latest one on both sides of the connection seem to be a stable fix.
French Community Moderator0 -
Having the same problem. My situation prevents me from upgrading my remote computers because they are located "Remotely". Teamviewer needs to enable backwards compatibility...
Support:
Updating my TV to the latest version did not help. The problem began suddenly without my doing anything, about 6 months ago. I think TV changed something somewhere. I have tried TV with Mac OSX and Win7, and both have the same issue.
The message about upgrading the remote TV is a total fabrication. I proved this by using an old TV to communicate with a new TV, and the message from the old TV said that the new TV is "old" and therefor needs upgrading. Of course this is total rubbish because at the time the old TV was written, it did not even know the new TV existed.
Clearly, somebody does not know what to do.
Please recommend something that works, or else, revert the changes from 6 months ago when this first happened.
Sorry to be so blunt, but lets get some people onto this situation who understands what is going on.
Garry.
2 -
This all came of TeamViewer shutting down access on their servers to all but the latest version of the "Free" unlicensed client without any notice and providing unhelpful error messages. I got the surprise suddendly after they threw the switch on the servers. TeamViewer on my new work laptop hadn't been activated and suddenly denied access with a misleading error message. Spent a lot of time and energy getting to the bottom of this that could have been avoided with a helpful error message and a link with details as to why the connection was not permitted. As soon as I activated my v12 client, I was back in business.
I can access any supported backlevel host with an Activated client. I don't believe that TeamViewer has ever supported connecting to a host at a version newer than the client.
@JeanK wrote:Hello @allitsolutions,
Hello @mspl,
Hello @ashwathn,Thank you for your messages.
Our goal is to provide you with the best service. Therefore, depending on your localization, we will ask you to update your TeamViewer client.
You will find all the information you need in our official announcement here: Updating to the latest and greatest version of TeamViewer
You get that link with the error message. It's not helpful because it doesn't attend to the actual reason the connection is denied.
@Yuri_T wrote:Hi @wroshon ,
YuriIt would be much more helpful to have said, make sure you have activated the backlevel client you are using with your TeamViewer license and it is not reporting the Free Version.
A lot of confusion, frustration and anger could have been avoided with a clear error message rather than "Unknown" and a message saying "You must be running the latest revision of TeamViewer to connect" with a link that lead to a page explained the situation fully. It would have also been helpful if the notifications that you are connecting to an older version said, "Please upgrade, the target because connections to older versions will no longer be supported as of -x- date". The former would have avoided confusion when you turned off access. The latter would have prevented a lot of users from getting here.
Users need a good reason to upgrade the software on the remote host. As the saying goes, "If it works, leave it alone"
?0
Hello @Djago
TeamViewer's official statement is to find in the following article: Enjoy using the best version of TeamViewer we made so far! - How to proceed?
- We are asking our free users with older versions of TeamViewer to update to the latest version of TeamViewer, in order to continue using the software. The latest version is currently TeamViewer 14.
Hi @JeanK
Perfectly clear. This solution is not suitable in many environments like the one I have in many companies (I do remote support for a living). Like others have stated, mixing free version for personal use of my clients and paid version for support (that's me) is not an option. So after many many years of using TeamViewer (I think I started with TeamViewer 3) I sadly have to switch to another program, at least for the free connection of my customers.
I've paid for the 3 simultaneous connection so I won't stop using it for my work because it was a very hard decision and a very expensive one and it works ok.
But as most people here are saying, I'm not going to buy another TeamViewer product, nor I will recommend it to anyone because you changed the rules after I bought the product. It is your product and you are completely free to do whatever you want with it, but for me, it's obvious that you no longer care for what your clients want or needs (and I mean free and paid users because you are messing with both).
Hi Djago:
I completly agree with your comments. I have now abandoned Team Viewer and switched to "**Third Party Product**", which works very well like Team Viewer used to work before they messed it up. I am in the process of updating all my friends and relatives to **Third Party Product**. Of course, I will not be using or recommending TeamViewer to anybody from now on.
This whole fiasco is an example of poor management decisions.
Garry.
From my new post, I see that this forum has censored the name of the competitive product, to which I just switched. The name is embedded and reversed herein. **Third party product** The act of censoring discussion forums indicates, to me, a high level of paranoia from a company that is unwilling to admit their mistakes. I think the expression is "Get Woke, Go Broke" Garry.
Hi @Djago , your comment is 100% like my situation, your thoughts too, i agree 100%, i think Teamviewer have just shoot in the foot.
Also is outrageous the way that they have censored @GarryAnderson comment too, i have never seen something like that.
Hey @JeanK , just let you know that i am Looking for free alternatives for my customers and never buying a TV product again. Maybe you can Forward this to the GENIUS that have the idea of this change in your commercial policy.
Both of my mac and remote windows 10 computer install the version 14, however it still says out of date when I use my Mac to control the windows 10. I tried several times, evern uninstall several times, it still doesn't work, please advise.
