Long network start
redkiynik
redkiynik Posts: 1
Hello. Windows 7 sp1 64. After upgrading to version 14.3.4730, after booting the PC for about a minute there is no network. When Teamviewer starts network appears. How it can be fixed?
update: that's what i mean
boot without TV
https://youtu.be/CvRgjvaFfCQ
boot with TV
https://youtu.be/Q6fJnvAIuC0
    Hello @redkiynik,
    This is indeed a known issue. Our development is working on a fix.
    We can currently provide you with a workaround.
    Solution: You need to set the TeamViewer service on Automatic (delayed start).
    You can do this by following these steps:
    1. Open Run on your computer (press Windows + R)
    2. Type in services.msc
    3. Find TeamViewer in the list, do a right-click on it and open the Properties.
    4. Under Startup type, select Automatic (delayed start), then press OK.
    Please understand that this is only a workaround and that our development is working on a fix.
    We wish you a pleasant rest of the day.
