french Accented Characters from windows TV to android host
dsly
dsly Posts: 2
Hi everybody,
I just install for the first time a TeamViewer Host in an android phone (sony Z3), it works fine from a windows 10 teamviewer, but I'm not able to write accented characters (é è à ê ...). All the keyboard seams to work, even the @, {[\`|[{#"'_- that we can do with the 'alt gr' key in French, even the ç (cedilla like in Besançon 25), but I'm not able to do a é or è or à... wich are in the same "line" on the keyboard than ç_-('", so, the line works fine, execpt for the accented characters ...
Does anyone experience the same issue ?
Thanks a lot !
Dsly
  • Chiron
    Chiron Posts: 229 ✭✭
    If the clipboard are synced you should be able to copy and paste. This can be a serious hassle if you need to do this often.
    Another option is Alt codes - Here is a link to a cheat sheet.
    https://usefulshortcuts.com/alt-codes/accents-alt-codes.php
    We had a user with and umlaut in his name (Ü) and it can be typed by holding down Alt and typing 0220 on the number pad.
  • dsly
    dsly Posts: 2
    OK thanks !, I'll do that !
    dsly
