Remote control in different version
JackieZhang
If I get latest lisenced version Teamviewer like 14, can I remote control to older version?
Hi @JackieZhang ,
Yes - you can remote control from the latest version to older version.
Hope this information will help you.Best regards,
YuriFormer Japanese Community Moderator0 -
Hi, I faced the same problem that connection failed when try to connect to an older version.
Error Message:
The remote TeamViewer is running an old version which is out of date, Therefore you cannot connect to this Version anymore. Your connection partner can update TeamViewer by clicking on "Help"-"Check for new version".
How to solve this without update the PC Team Viewer, because there is no one control that PC. It is quite far away from my current location.
