When attempting to install Teamviewer host on a raspberry pi 4 using raspbian - buster, the following error is generated after sudo teamviewer setup is completed
The framebuffer console seems to be unavailable or has the wrong format. For
connections to framebuffer consoles to work please make sure that /dev/fb0 is
accessible and configured to at least 16-bit depth.
On my raspberry pi 2, installing Teamviewer on the same raspbian buster image works fine.
Any ideas?
