traffic
harbor
harbor Posts: 2
how much traffic does the program consume in standby mode per day ?
  • Ying_Q
    Ying_Q Posts: 2,601 Moderator
    Hi @harbor
    It is unfortunately not possible to tell you exactly how much data TeamViewer will be using during a connection as this largely depends on what you do during the connection (e.g. whether you work with a software, look at videos or transfer files to or from the remote computer).
    However, you can always check how much data TeamViewer is using during a specific connection by going to the "Actions" tab in your remote control toolbar. To the very right, you will see the "Information" section, which includes "Remote system info" and "Remote update". By clicking on the small arrow in the right-hand corner, you can open the "Connection Info" window. In that window, you will be able to see the amount of data transmitted during the current session under "Traffic".
    Feel free to browse the Community Article - Data flow between device connections for more information.
    I hope this helps. If you have any further questions, please don't hesitate to let me know.
    Kind Regards
    Community Moderator/中文社区管理员
  • harbor
    harbor Posts: 2
    ok, thanks
    I was referring to how much data TeamViewer uses during inactivity, per day
    approximately...
    (I have a traffic limit of 150 megabytes per month)
