Wifi Direct Connection with Win10 and iPad
Hey Community,
i am trying to view my computer desktop on my iPad via wifi direct. Sadly i couldnt find any answers on how to do this. Has someone ever done this?
I do not have a hotspot around where i need to view the win10 screen, so i thought i could use a wifi direct connection to stream my monitor on my iPad. Maybe some can help me with this problem.
Greetings, Robin
    Hello @Acidfie
    Firstly you need to download TeamViewer for iOS on your iPad.
    The rest is basic TeamViewer use:
    1. Type in the ID of your Windows computer
    2. Type in the Personal password you have set up on your computer
    3. That's it - you are now remotely connected to your computer.
    Cheers,
  • Acidfie
    Hi Jean,
    this is sadly not solving my problem, because it requires a wifi router/hotspot where these 2 devices are connected to.  I already know that teamviewer can be used with LAN only mode, thats why i am trying to build a direct connection between iPad <-> Computer. They should use wifi direct to be connected to eachother, creating their own network. I do not  have an internet connection, nor a router. Only two devices.
    Greetings,
    Robin
    Hello @Acidfie
    If you want to use TeamViewer in a LAN network, you need to read this article: Can TeamViewer be used within a local network (LAN) only?
    Note: Currently, a bug prevents connecting from an Android to a computer within a LAN network. Our dedicated team has worked on a fix that will be released soon.
    Cheers,
  • Acidfie
    Hi Jean,
    i know that i can use Teamviewer within a LAN connection, this is not the exact case here.
    i have an iPad, that is not connected to any network (no LAN, no WIFI). Then i have a Laptop with a Wifi-Direct capable network card. I want to connect my iPad directly to my Laptop via WiFi Direct (This enables the possibility that 2 devices build a network without needing a router). I am asking if this is possible because my iPad is connected to my PC via a hotspot, but i cant connect with teamviewer.
    Greetings, Robin
    Hello @Acidfie
    Unfortunately, your second explanation hasn't helped a lot to understand your issue.
    You are saying two different things.
    On one hand, you say that your iPad is not connected to any network (Lan, WiFi etc...) and on the other hand, you say that your iPad is connected via the Hotspot of your laptop.
    I asked a network engineer to read your post and he confirmed that he does not understand your issue either.
    Could you please reformulate what your question actually is?
    Many thanks in advance for your understanding.
    Cheers,
  • Acidfie
    Hello Jean,
    sorry for the confusion.
    My iPad is connected to my Win10 Laptop via a Mobile Hotspot. A direct connection with no other clients. Only the iPad and the Laptop. I can extract the IP-Adress of the iPad and i can see the IP Adress of my laptop, but i cant make a connection with teamviewer.
    There is no internet connection available, not on the iPad and not on the Laptop.
    Greetings, Robin
