How to Remove a Computer completely from Computers and Contacts?
Druzil
Druzil Posts: 1
as the Topic sais. how can i remove a Computer completely fro my Account ?
havent found anything
  • DomLan
    DomLan Posts: 490 ⭐Star⭐
    @Druzil
    You can remove a contact by right-clicking on the single entry.
    If you are the one who provides support and you do so by sending a QuickSupport module or an Host module, you can configure the latter to NOT automatically save the contacts at the end of the connection
    I hope I understand your request and that this can help
    Domenico Langone
    MCSD: App Builder
  • ikloecker
    ikloecker Posts: 1
    OK,
    but how it is possible to delete all contacts in a group. I ordered my contaczts and create a group named todelete. Now I plan do delete all members of this group.
