TeamViewer 14 Not ready. Please check your connection.
JasonSeah
JasonSeah Posts: 1
Currently using teamviewer version 14.2.2558
3 different computer login teamviewer 14 always show Not ready. Please check your connection.
May I know how to resolve this issue?
    Hello @JasonSeah,
    I recommend you to restart the TeamViewer service.
    -Execute run, type services.msc and press OK
    -Now find TeamViewer, and restart it by doing a right click.
    Then, restart the TeamViewer application. It should work again.
    Best regards
    Jean Kinzler
  • nr1957
    nr1957 Posts: 1
    Restarted TeamViewer. Did not help. Still says "Not ready. Check your connection"
