Servicecamp - From address & custom domain
Hi @Esther or @Jeremy,
How do we remove the '(servicecamp)' from the FROM address of our tickets?
We have setup our relevant Inboxes with differing Email display name, but (servicecamp) is added.
On that note, is it on the development list to allow 'Proper' custom domains within servicecamp, rather than just the subdomain, so that the end user receives emails from the company.servicecamp.com.
Thanks in advance for your reply.
Karl.
  • Jeremy
    Hi @sws_karls,
    Thanks for your feedback! Currently there's no way to remove the "(serviccamp)" from the email sender name, nor to change the sender address to your own domain name. However, I have passed these two points on to our product management so they are aware of the request for this.
    Jeremy
  • alexiss
    Has this been addressed?
  • Yervand_PM
    Yervand_PM Posts: 102 Staff member 🤠
    Hi
    Now you can configure an outgoping mail server as well via SMTP protocol and send all replies to your customers from your domain name instead of serivcecamp.com
    Yervand
    Product Owner
  • GamalElsasabbag
    how about incoming ? can i configure servicecamp to recive directly from my @company.com domain directly.?
  • alexiss
    looks like the email check is slow - is there a way to configure the interval?
    also, SMTP does not seem to work for email
  • alexiss
    SMTP problem with gmail:
    Outgoing connection failed with the following error:
    Called HELO without being connected
  • Peter_AB
    We have this problem too.
    Anyone knows what the problem is and how to solve it?
    Peter
  • Peter_AB
    Peter
    Ok, issue with outgoing mail on gmail/Gsync is:
    Use smtp.gmail.com, port 587 and STARTTLS, this is working for me.
  • alexiss
    Great, thank you for sharing.  I set up a forward to servicecamp so far, it seems to be working.  Naturally, replies are from the servicecamp address and not ours.  But at least clients can initiate tickets via the intended email.
  • lelle68
    As I understan the issue with outgoing mail address should be solved, but there are no field in own mail server setting to set a reply address.
    I suppose that means that you have to have email address as usersname, that is not true in our case.
    I have setup to use your my own server for incomming and outgoing imap and smtp but still it't the @servicecamp.com that are visiblie on outgoing e-mails. Any suggestions howto solve this?
    /Lennart
  • lelle68
    Never mind, I was wrong. It worked as it should do. New mails are from our support@ourdomain.com
