Windows 10 does not look to start service until logon
I would like to inform you what we know so far and where exactly we are on this problem.
First, I would like to dispense some false information that I read here in this thread:
- The problem is not about the TeamViewer service startup not working or about incorrect service settings. The service starts fine after the PC is booted. You should not enable the interactive mode for the service as this can prevent the service from running on some PCs.
- The Windows 10 Creators update doesn't always break TeamViewer. Actually, we are still not able to find a single device here that had any problems after the Creators update, which makes this problem very hard to analyze or fix.
So what is the problem?
As far as we can tell the TeamViewer service cannot open outgoing TCP connections while there is no user logged in. And if that doesn't work you'll not see the device as “online” and won't be able to connect to it using the TeamViewer ID. Incoming connections on the other hand are completely fine, which is why connections using the IP or hostname work. Existing connections will stay alive if the user logs out, and that's why devices stay online in TeamViewer. However, connecting to it will not work as in this case the TeamViewer service would try to create a new outgoing connection.
This all doesn't seem to be a bug in TeamViewer and therefore we also probably cannot fix it. It's much more likely that this is a bug in Windows and therefore we assume it might be a Microsoft issue.
Which devices are affected?
At first, we only received reports from users with Lenovo or Fujitsu devices. However during the last few days, we also received some reports about devices from HP, Dell and ASUS. This means that in general there doesn't seem to be a common factor on the manufacturer side. We assume that the fact that the issue occurred only on devices from two manufacturers at the beginning might be related to the rollout strategy for the Windows Creators update.
The hardware and software on the devices is also very diverse, so we cannot pinpoint it to anything more specific there either. Right now, our best guess is that it's a setting on those devices or in the network they are connected to that is causing this problem. But we don't have enough data to see what exactly that setting could be.
What might help to fix this problem?
So far, we have received three cases where a user reported that something fixed the problem.
- The first one was to remove the USBPcap driver (part of Wireshark).
- The second one was that it fixed itself over night after a Windows update.
- And the third one was to not use proxy discovery over WPAD (source: https://superuser.com/questions/1198203/make-teamviewer-work-before-user-login#comment1752259_1198203).
We did not find USBPcap on any of the other devices that are affected by this problem. Also, the Windows update that was installed is also installed on all the other device that still have the problem. Most users also didn't use a proxy to connect to the Internet once they were logged in. So, while this might work for some other people, none of this sounds like the real solution.
What did we do so far?
- We checked and compared a lot of support collector data from different users. As stated above so far there's no real common theme anywhere.
- We inspected our network code to see if anything there might be wrong and could explain the errors we see, but could not find anything.
- We tried to raise this issue with Microsoft, yet so far they are not aware of any problems. We will continue to stay in touch with them as we believe this might be where the issue may be raised.
- We set up different PCs and notebooks with Windows 10 + Creators update in different network environments, but so far all of them work as expected. We still have a few notebooks left though and will continue to try to reproduce it here.
How can you help?
In order to solve this issue as quickly as possible we kindly request you to support us with your help:
- Please post this problem in the Windows 10 feedback app from the PC where it occurs. This helps us to broaden the awareness about this issue on the Microsoft side so that they also start investigating it. It can also give Microsoft some data for the PCs that are affected by it that we don't have yet.
- If you can provide some additional information about your network settings and infrastructure that would also help:
- Are the PCs in a domain (I think that was already answered as "doesn't matter")?
- Did you configure the PCs in any special way to be able to join your network or do you have anything in your LAN that blocks unknown devices?
- Please check the firewall (local and hardware firewall, if available) for error messages / ports being blocked / etc. for destination *.teamviewer.com. Is there anything being blocked? And if so, why?
- Are there any port limitations for local ports of outgoing connections (for example: only allow port starting at 32765, or similar)?
- Please check the output of the following two commands and post them here if they don't match the expected values:
1) netsh int ipv4 show dynamicportrange tcp
2) netsh int ipv4 show excludedportrange tcp
The first command should show a starting port of around 49152 and a total count of about 16384.
The second command should show an empty list. - Run autoruns (https://technet.microsoft.com/de-de/sysinternals/bb963902.aspx) and check the Winsock Providers and Network Providers tab. Is there anything in there?
Thank you very much for your collaboration and understanding!
Maurice
Software Developer12 -
fyi I am having the same issue on windows 7 ultimate 64bit - so is suspect it has nothing to do with windows 10.......
To be a little more clear....
I have a win10 and a win7 machine, both running the same version of teamview (12.0.77242) and both having "start teamviewer with windows" and "Full access control when a partner is connecting to the windows logon screen"
If i try to connect to the win7 machine (that is sitting at the windows login prompt) from the win 10 machine it CANNOT connect.
If i try to connect to the win10 machine (that is sitting at the windows login prompt) from the win 7 machine it DOES connect.
I downgraded the teamview on the win7 machine and that did not fixe the problem -
so its like its not a win 10 problem and its not a teamviewer problem - so it must be a config problem ???
I haven't been having any trouble with TeamViewer 12 and Windows 10 when using this script linked here:
Add the following outgoing firewall rules in Windows 10... you can do so by running the following in an elevated PowerShell window:
New-NetFirewallRule -DisplayName "!Allow Outbound UDP svchost.exe" -Enabled True -Direction Outbound -Profile ANY -Protocol UDP -Program "C:\WINDOWS\system32\svchost.exe" -Action Allow -Description "Allows Outbound UDP svchost.exe."
New-NetFirewallRule -DisplayName "!Allow Outbound TCP TeamViewer_Service.exe" -Enabled True -Direction Outbound -Profile ANY -Protocol TCP -Program "%ProgramFiles% (x86)\TeamViewer\TeamViewer_Service.exe" -Action Allow -Description "Allows Outbound TCP TeamViewer_Service.exe."
New-NetFirewallRule -DisplayName "!Allow Outbound 5938 UDP TeamViewer_Service.exe Local Port" -Enabled True -Direction Outbound -Profile ANY -LocalPort 5938 -RemotePort ANY -Protocol UDP -Program "%ProgramFiles% (x86)\TeamViewer\TeamViewer_Service.exe" -Action Allow -Description "Allows Outbound TeamViewer_Service.exe communication via 5938 UDP."0 -
Here are additional information from my PC :
- NO
- NO
- Nothing of this type
- No limitation
The second command should show an empty list.- First command OK
- Second command : shows port 19455-19455
- Network providers : empty
- Winsock providers : shows 2 entries :
mdnsNSP Bonjour Namespace Provider Apple Inc. c:\program files (x86)\bonjour\mdnsnsp.dll
mdnsNSP Bonjour Namespace Provider Apple Inc. c:\program files\bonjour\mdnsnsp.dll
0 - Are the PCs in a domain (I think that was already answered as "doesn't matter")?
Well, I think I know what happens, but I have no idea why.
This is an excerpt from a WFP event capture on 1703:
<netEvent>
<header>
<timeStamp>2017-05-09T22:12:26.351Z</timeStamp>
<flags numItems="9">
<item>FWPM_NET_EVENT_FLAG_IP_PROTOCOL_SET</item>
<item>FWPM_NET_EVENT_FLAG_LOCAL_ADDR_SET</item>
<item>FWPM_NET_EVENT_FLAG_REMOTE_ADDR_SET</item>
<item>FWPM_NET_EVENT_FLAG_LOCAL_PORT_SET</item>
<item>FWPM_NET_EVENT_FLAG_REMOTE_PORT_SET</item>
<item>FWPM_NET_EVENT_FLAG_APP_ID_SET</item>
<item>FWPM_NET_EVENT_FLAG_USER_ID_SET</item>
<item>FWPM_NET_EVENT_FLAG_IP_VERSION_SET</item>
<item>FWPM_NET_EVENT_FLAG_PACKAGE_ID_SET</item>
</flags>
<ipVersion>FWP_IP_VERSION_V4</ipVersion>
<ipProtocol>6</ipProtocol>
<localAddrV4>192.168.92.134</localAddrV4>
<remoteAddrV4>192.168.92.6</remoteAddrV4>
<localPort>49950</localPort>
<remotePort>3128</remotePort>
<scopeId>0</scopeId>
<appId>
<data>5c006400650076006900630065005c0068006100720064006400690073006b0076006f006c0075006d00650034005c00700072006f006700720061006d002000660069006c00650073002000280078003800360029005c007400650061006d007600690065007700650072005c007400650061006d007600690065007700650072005f0073006500720076006900630065002e006500780065000000</data>
<asString>\.d.e.v.i.c.e.\.h.a.r.d.d.i.s.k.v.o.l.u.m.e.4.\.p.r.o.g.r.a.m. .f.i.l.e.s. .(.x.8.6.).\.t.e.a.m.v.i.e.w.e.r.\.t.e.a.m.v.i.e.w.e.r._.s.e.r.v.i.c.e...e.x.e...</asString>
</appId>
<userId>S-1-5-96-0-2</userId>
<addressFamily>FWP_AF_INET</addressFamily>
<packageSid>S-1-15-2-95739096-486727260-2033287795-3853587803-1685597119-444378811-2746676523</packageSid>
<enterpriseId/>
<policyFlags>0</policyFlags>
<effectiveName/>
</header>
<type>FWPM_NET_EVENT_TYPE_CLASSIFY_DROP</type>
<classifyDrop>
<filterId>66432</filterId>
<layerId>48</layerId>
<reauthReason>0</reauthReason>
<originalProfile>3</originalProfile>
<currentProfile>3</currentProfile>
<msFwpDirection>MS_FWP_DIRECTION_OUT</msFwpDirection>
<isLoopback>false</isLoopback>
<vSwitchId/>
<vSwitchSourcePort>0</vSwitchSourcePort>
<vSwitchDestinationPort>0</vSwitchDestinationPort>
</classifyDrop>
</netEvent>This is the TeamViewer service attempting an outbound connection to an HTTP proxy. The attempt fails, as can be seen from the FWPM_NET_EVENT_TYPE_CLASSIFY_DROP.
The event references the filter rule with ID 66432. This is it:
<item>
<filterKey>{9a00657e-fe37-47c1-818c-f643513fc2fe}</filterKey>
<displayData>
<name>Block Outbound Default Rule</name>
<description>Block Outbound Default Rule</description>
</displayData>
<flags/>
<providerKey>{4b153735-1049-4480-aab4-d1b9bdc03710}</providerKey>
<providerData>
<data>6000000000000000</data>
<asString>`.......</asString>
</providerData>
<layerKey>FWPM_LAYER_ALE_AUTH_CONNECT_V4</layerKey>
<subLayerKey>{b3cdd441-af90-41ba-a745-7c6008ff2300}</subLayerKey>
<weight>
<type>FWP_EMPTY</type>
</weight>
<filterCondition numItems="1">
<item>
<fieldKey>FWPM_CONDITION_ALE_PACKAGE_ID</fieldKey>
<matchType>FWP_MATCH_NOT_EQUAL</matchType>
<conditionValue>
<type>FWP_SID</type>
<sid>S-1-0-0</sid>
</conditionValue>
</item>
</filterCondition>
<action>
<type>FWP_ACTION_BLOCK</type>
<filterType/>
</action>
<rawContext>0</rawContext>
<reserved/>
<effectiveWeight>
<type>FWP_UINT64</type>
<uint64>549755813888</uint64>
</effectiveWeight>
</item>This rule applies whenever its single condition matches. The condition is that the "package ID" of the packet's (actually, the connection's) originator is not S-1-0-0 (no identity), or in other words, it matches everything that has a package ID.
In the event trace, we see that the TeamViewer service process has a package ID, wherever it may have acquired it, hence it matches this rule and its traffic is blocked.
I have no idea where the rule comes from (except that it is a Windows Firewall rule per its provider ID) or what it may be intended to do. My current guess is that "modern" apps are not supposed to communicate when no user is logged on.
I cannot prove that this is any different on 1607, because apparently WFP captures do not include permitted packets. According to Process Explorer, the service process has no application package SID in either version.
2 -
From the WFP trace:
From the list of app containers:
Container:
SID: S-1-15-2-95739096-486727260-2033287795-3853587803-1685597119-444378811-2746676523
Display name: Usermode Font Driver HostThat is clearly the same SID. So how does the TeamViewer service get stuck with the "font driver host"'s package identity?
@chrullrich That's a very interesting bit of information. The fact that the service is using the SID of a different user is definitely not correct if there's no user logged in. We will fix that but before that could you test if that would solve the problem?
To test it you need to disable the Windows Firewall service.
Maurice
Software Developer0 -
@Maurice, yes, with the service disabled, the computer shows up immediately after rebooting, and I can connect to it.
Also, there is plenty of other evidence that the firewall is interfering: The TV log says something about "connection failed" due to "bad access", the Security event log is full of events 5152 (firewall blocked packet) and 5157 (firewall blocked connection), both referring to teamviewer_service.exe, and my network trace clearly shows that the connection attempts do not reach the switch.
Please be aware that this SID is not a user SID, and is not used as one by the firewall. An application package identifier is a SID that is used for sandboxing processes, both "modern" apps and such others as opt in to this protection. As the name says, it identifies an application, not a user.
I turned the windows firewall service off on one of my computers with windows 10 1703 on the domain and rebooted. It did show up on the list and I was able to log in to it like normal unattended access. Turned windows firewall service back on, rebooted and can't access it until someone logs in.
I've upgraded a couple machines to 1703 and one machine is fine and the other never appears in my console after boot. I've noticed the service does not start, and so far I've been able to fix it by setting the service to "delayed start" and it then appears in my console as online automatically. I had to have a user manually start it on the other end every time.
For me this didn't work. It doesn't make any difference whether the Windows firewall is stopped or running, only after someone is logged on (either locally or remote via rdp) the machine shows up as online under TV computer and contacts.
It is w10-x64 v1703 updated from v1607
Confirmed here too. I had previously tried turn off the firewall in the GUI with no effect, but disabling the service shows the workstation online immediately after reboot, without user interaction.
I've tried turning off the firewall in the GUI for each connection type in turn (in case it wasn't immediately identifying as a domain connection, etc) and for all three at once, but only disabling the service has the desired effect.
Hopefully TeamViewer can confirm that they are working on a fix for this, or talking to Microsoft? As disabling the FW is obviosuly not an option and TV is therefore not currently fit for purpose.
I disabled the Windows Firewall service and it is available after reboot without anyone having to log in. I didn't use the firewall GUI. When I re-enabled the Windows Firewall Service and rebooted, I was back to having to have someone login or RDP to the machine.
Why can't TeamViewer come up with a solution? I bet LogMeIn doesn't have this problem.
I agree, teamviewer should of had this problem fix by now. I know they said none of their machines have this problem when they rolled Win10 1703. I find that hard to believe when I installed it on 5 computers and I have this problem on all 5. I rely on unattended access several times DAILY. I would be forced to switch to a more reliable solution very soon. Guess time to start looking for an alternative at least.
Basically Teamview people do not care. That is obvisous.
Our response is also obvisou, to find another provider who does offer functionality you would expect t find in a v0.0.0.01 of a product.that is not present is Teamviewer.
Can any suggest altenratives? Let use their messeaging system to find a competitor.....
The latest build offered by TV support team seems to fix this problem. Guess this version will be released soon to public0
Is this build for TV11, TV12 or ALL versions? I'm not paying for TV12 when TV11 does all I need it to do.
I have written a workaround that works for me. If any of you are desperate enough to consider using it, you can find it at [link removed]
However, I seriously recommend that you do not use it, because you have no reason whatsoever to trust me with administrative access to your firewall policy, which is what it needs.
TeamViewer scheint an einer Lösung zu arbeiten, heute Morgen habe ich eine Mail erhalten, dass hier in diesem Thread ein neuer Beitrag von WouterGlas geschrieben wurde.
Warum dieser Beitrag vom Support wieder entfernt wurde kann ich nicht sagen, er enthielt aber bereits 2 EXE-Dateien, die lt. Angabe von User WouterGlas funktionieren würden.MSI Dateien so schrieb er, würden im nächsten Release von nachgereicht werden.
Inzwischen funktioniert der Download der EXE-Dateien nicht mehr mit dem Hinweis, dass der Support diese entfernt hat.
Meine Tests mit der Host-Version dieser Dateien war aber auch erfolgreich!Es gibt mir etwas Hoffnung zu wissen, das der Support zumindest an dem Thema arbeitet. Auch wenn ich mir wünschen würde, dass sie uns besser über den aktuellen Stand informieren.
________________________
TeamViewer seems to find a solution to work this morning, I have received an email that here in this thread a new post was written by WouterGlas.
Why this post has been removed by the support I can not say it contained but already 2 .exe files, that would work according to the specification of user WouterGlas.MSI files so he wrote would in the next release of be submitted.
Meanwhile download of the .exe files no longer works by pointing out that the support has removed these.
My tests with the host version of these files was also successful.It gives me something to know hope that the support is working at least on the subject. Even though I would wish that they better inform us about the current status.
Thank you for your contribution here.
Yes, it is true that we found a solution for the problem - we gave a CustomBuild to a few customers to test it and it seems like we finally found a fix for the problem.
However, we cannot publish this version at the moment since it is a CustomBuild and not an official TeamViewer release. I will inform you, when we published an official version.
A big THANK YOU to everyone here who helped us with giving system information or testing different things Maurice asked for.
And of course a big THANK YOU to @Maurice our developer who fixed this.
Julia
Find this helpful? Say thanks by clicking on the Thumbs Up button.3 -
Hi again,
We've discussed this topic again internally and have come to the conclusion that we want to share with everyone the Custom Build that contains the fix.
Here you can find the links (version 12) for the Host module and the full version:
We do NOT guarantee that this version is without any bugs – as I said in my previous post, this is not an official release. There could potentially still be other bugs included – it’s up to you if you want to install this version or not.
CheersJulia
Find this helpful? Say thanks by clicking on the Thumbs Up button.1 -
Will they be coming out with a fix for a version 11?
Hallo Julia,
gibt es schon Informationen wann eine MSI Datei verfügbar ist? Für das Ausrollen per GPO. Die Host-Version läuft auf einer Testmaschine bisher ohne Probleme.
Darf man erfahren wodurch das Problem entstanden ist und wie Eure Entwicklung es lösen konnte?
__________________
There is already information when an MSI file is available? For the roll-out via GPO. The version of the host runs on a test machine so far without problems.
Can you tell us which the problem occurred and how your development could solve it?
As far as I know the MSI file will be available with the next official release, or shortly after that.
As for what the problem was, or what we fixed. The TeamViewer service tries to connect when it first starts using TCP. on port 5938. For some reason this first connection fails on some systems. This could have a couple of reasons (Firewall, network not yet ready, etc.). In theory this should not matter.After the first failed connection attempt the service tries to connect using HTTPS, and that's where the problem was. For HTTPS it's possible that there is a proxy in use and proxy settings are normally user settings. So the service checks if there is a user logged in and tries to impersonate that user. And for that check we had a bug because we didn't filter out app container users, which were introduced in Windows 8 to limit access to unneeded resources (e.g. the network). Until the Windows 10 Creators update this didn't cause any problems, but after it the TeamViewer service found such a user and impersonated it, which meant the serivce was using a user that has no access to the network device. So we fixed our check for logged in users and filtered out app container users.
Maurice
Software Developer2 -
Thanks for the explanation.
In our case, it was the firewall, blocking the way out of our network. Any unnesseccary ports are blocked (including 5938), and HTTP(S) is only allowed for authenticated users. Before the Creator's update, the Teamviewer service was still able to pass through for whatever reason, but after the update, the impersonation must have triggered the blocking mechanism, leaving the service unable to notify the TV server.
The moment I opened up port 5983 for outgoing traffic, a test computer from inside our LAN appeared in my contact list as online.
As I highly doubt that TV 10 will get patched (that's what we use), I have to evaluate to either keep that port open or simply allow all HTTPS traffic to TV servers (which should work as well, according to the explanation above)...
For anyone trying this, it is NOT port 5983. I spent too long scratching my head on it.
The correct port is TCP/5938. (as in, your PC will talk TCP from a random-high-number port to the TeamViewer servers at destination port 5938).
Had a coworker try inserting the firewall rule just to make sure I wasn't going screwy. His dyslexia kicked in and he read 5938 on the above post and viola that worked instantly as described. Double checked with TV support documents (should have done to start with) and the correct port is TCP/5938.
Confused by this answer. 1703 doesn't run without this KB in place?
Prerequisites
If you are running Windows 10 Version 1511, to install this update, you must have installed cumulative update KB4016636, or a subsequently released Windows 10 cumulative update. If you are running Windows 10 Version 1607 you must have installed cumulative update KB4015217, or a subsequently released Windows 10 cumulative update. Note: KB4013214 is required before Windows Update will download and install the Windows 10 Creators Update.
