TeamViewer 14 doesn't open after trying to open it after 2 months since I opened it last time
emrefez4
emrefez4 Posts: 1
TeamViewer 14 doesn't open after trying to open it after 2 months since I opened it last time. I tried to re-install it but nothing has changed. Then it came to my mind that I could reboot, I rebooted my pc but nothing has changed. I re-installed it 3-4 times but nothing changed. When I try to open it it shows an error message that the programme can't be found on my pc. Can someone help me? Ty
  • Ying_Q
    Ying_Q Posts: 2,598 Moderator
    Hi @emrefez4
    Can you kindly try to tick the option of Remove Settings when you are uninstall TeamViewer please. Then visit TeamViewer download page to download TeamViewer please. Meantime, kindly check out Which operating systems are supported? for software and operating system version compatibility please.
    Hope the steps above are helpful.
    Community Moderator/中文社区管理员
