TV 14 "Not ready..." on Manjaro KDE
I have tried just about everything suggested in all the threads on this forum, still can not get it to work.
❰greg❙~❱✔≻ sudo systemctl status teamviewerd
● teamviewerd.service - TeamViewer remote control daemon
Loaded: loaded (/usr/lib/systemd/system/teamviewerd.service; enabled; vendor preset: disabled)
Active: active (running) since Fri 2019-10-25 22:03:32 BST; 43s ago
Process: 30817 ExecStart=/opt/teamviewer/tv_bin/teamviewerd -d (code=exited, status=0/SUCCESS)
Main PID: 30819 (teamviewerd)
Tasks: 16 (limit: 4915)
Memory: 4.3M
CGroup: /system.slice/teamviewerd.service
└─30819 /opt/teamviewer/tv_bin/teamviewerd -d
Oct 25 22:03:31 greg-pc systemd[1]: Starting TeamViewer remote control daemon...
Oct 25 22:03:32 greg-pc systemd[1]: Started TeamViewer remote control daemon.
❰greg❙~❱✔≻ /opt/teamviewer/tv_bin/script/teamviewer
Init...
CheckCPU: SSE2 support: yes
Checking setup...
Launching TeamViewer ...
Launching TeamViewer GUI ...
❰greg❙~❱✔≻
I have rebooted,
Tried wired connection &/or wifi,
Tried open DNS,
It's not the firewall (switched off while testing this),
started the service,
stopped and re-started the service,
re-installed teamviewer,
re-boot system some more just for fun...
Im open to any suggestions as i need to assist my dad get his printer installed but im as stuck on this as he is on that.
Im on Manjaro KDE, All up to date.
Host: greg-pc Kernel: 5.3.6-1-MANJARO x86_64 bits: 64 compiler: gcc v: 9.2.0 Desktop: KDE Plasma 5.16.5 Distro: Manjaro Linux
  • rolandg
    rolandg Posts: 64 ✭✭
    hi,
    i've install a Manjaro with KDE in a VM; installed Teamviewer 14 ( tar dist.);
    it works ( incoming and outgoing connecttion) fine from the first attempt.
    you description is a bit confusing to me. I assume, that you want to do an outgoing connection from your Manjaro box to your dads ( windows? ) PC. right?
    did you check the TV log files in the directory logfiles ?
  • Hi, Yes you assume correctly, I am trying to connect from my linux to a windows client to offer support.
    My log file:-
    Start:              2019/10/26 07:32:02.839 (UTC+1:00)
    Version: 14.6.2452
    Loglevel: Info (100)
    License: 0
    Server: master14.teamviewer.com
    IC: -**Please do not post TeamViewer IDs**
    CPU: Intel(R) Core(TM) i5-7200U CPU @ 2.50GHz
    CPU extensions: l9
    OS: Lx Manjaro Linux (x86_64)
    IP: 192.168.2.106
    Proxy-Settings: Type=0 IP= User=
    2019/10/26 07:32:02.849 13964 **Please do not post TeamViewer IDs**20672 GX0 SystemID m=1 s=1 f48ad995d1d94f05a2259fdf8e02a280
    2019/10/26 07:32:02.850 13964 **Please do not post TeamViewer IDs**20672 GX0 DynamicPasswordUIModel::ShouldShowDynamicPassword(): dynPw=1 allowIncoming=1 id=0 ka=0 lanAllowed=0 lanOnly=0 networkState=1 showDynPwd=0
    2019/10/26 07:32:03.173 13964 **Please do not post TeamViewer IDs**20672 GX0!! ApplicationLookOfflineState::ApplicationAppearanceOfflineState: state not loaded, Errorcode=25
    2019/10/26 07:32:03.173 13964 **Please do not post TeamViewer IDs**20672 GX0 ManagerHolderStateMachine: Switching from None to NotReady
    2019/10/26 07:32:03.173 13964 **Please do not post TeamViewer IDs**92640 GX0 ChatManager::ChatManager: created
    2019/10/26 07:32:03.173 13964 **Please do not post TeamViewer IDs**92640 GX0 ChatManager::Factory: ChatManager created
    2019/10/26 07:32:03.173 13964 **Please do not post TeamViewer IDs**92640 GX0 IncomingBetterChatCommandHandler::IncomingBetterChatCommandHandler: created
    2019/10/26 07:32:03.173 13964 **Please do not post TeamViewer IDs**92640 GX0 IncomingCommandRegistration::Start: registering for ready state properties
    2019/10/26 07:32:03.174 13964 **Please do not post TeamViewer IDs**20672 GX0 Initialised XFixes extension (base=87 error=140)
    2019/10/26 07:32:03.177 13964 **Please do not post TeamViewer IDs**20672 GX0 DBusStatusNotifier: registered at org.kde.StatusNotifierWatcher
    2019/10/26 07:32:27.459 13964 **Please do not post TeamViewer IDs**68192 GX0 XClipboard: Shutting down event loop
    2019/10/26 07:32:27.460 13964 **Please do not post TeamViewer IDs**20672 GX0 Chat::Stop: Stopping chat
    2019/10/26 07:32:27.460 13964 **Please do not post TeamViewer IDs**20672 GX0 ChatManager::UnregisterIncomingCommandRegistration: destroying incomingCommandRegistration
    2019/10/26 07:32:27.460 13964 **Please do not post TeamViewer IDs**20672 GX0 IncomingCommandRegistration::Stop: disconnecting ready state properties
    2019/10/26 07:32:27.460 13964 **Please do not post TeamViewer IDs**85344 GX0 ChatManager::Close
    2019/10/26 07:32:27.460 13964 **Please do not post TeamViewer IDs**85344 GX0 ChatManager::UnregisterIncomingCommandRegistration: destroying incomingCommandRegistration
    2019/10/26 07:32:27.461 13964 **Please do not post TeamViewer IDs**85344 GX0 ChatManager::ClearAccountChat: clearPersistently = 0
    2019/10/26 07:32:27.461 13964 **Please do not post TeamViewer IDs**85344 GX0 ChatManager::ClearNonAccountChat
    2019/10/26 07:32:27.461 13964 **Please do not post TeamViewer IDs**20672 GX0 ChatManager::~ChatManager: destroyed
    2019/10/26 07:32:27.461 13964 **Please do not post TeamViewer IDs**20672 GX0 IncomingBetterChatCommandHandler::IncomingBetterChatCommandHandler: destroyed
    2019/10/26 07:32:27.520 13964 **Please do not post TeamViewer IDs**92640 GX0 CTcpProcessConnector::HandleRead(): Socket gracefully closed (PID=2515)
    2019/10/26 07:32:27.520 13964 **Please do not post TeamViewer IDs**92640 GX0 CTcpProcessConnector::CloseConnection(): PID=2515
    2019/10/26 07:32:27.520 13964 **Please do not post TeamViewer IDs**92640 GX0 InterProcessBase::EventFunctionInternal(): IPC-Connection Closed
    2019/10/26 07:32:27.520 13964 **Please do not post TeamViewer IDs**92640 GX0 CTcpProcessConnector::CloseConnection(): Shutdown socket returned error 107: Transport endpoint is not connected
    2019/10/26 07:32:27.541 13964 **Please do not post TeamViewer IDs**20672 GX0 Shutting down System DBus
    2019/10/26 07:32:27.542 13964 **Please do not post TeamViewer IDs**20672 GX0 InterProcessConfigurationHub::SendToConfigurationHandler(): IPC not available, could not send command: CC=1 CT=110
    2019/10/26 07:32:27.542 13964 **Please do not post TeamViewer IDs**20672 GX0 interprocessbase::SecureNetwork destroyed
    2019/10/26 07:34:07.351 15056 **Please do not post TeamViewer IDs**26688 GX0 Logger started.
    2019/10/26 07:34:07.351 15056 **Please do not post TeamViewer IDs**26688 GX0 Found 0 stack dump files ...
    2019/10/26 07:34:07.351 15056 **Please do not post TeamViewer IDs**26688 GX0 Found 0 core dump files ...
    2019/10/26 07:34:07.352 15056 **Please do not post TeamViewer IDs**26688 GX0 systemd: logind service available
    2019/10/26 07:34:07.354 15056 **Please do not post TeamViewer IDs**26688 GX0 systemd: New seat seat0 [path=/org/freedesktop/login1/seat/seat0, activeSession='1', canGraphical=1, canTTY=1, canMultiSession=1]
    2019/10/26 07:34:07.354 15056 **Please do not post TeamViewer IDs**26688 GX0 LogindSessionInfo: New session LogindSessionInfo [id=1 user=greg state=user active=1 reliable=1 infoId=**Please do not post TeamViewer IDs**] [path=/org/freedesktop/login1/session/_31 TTY= seat=seat0 display=:0 vtnr=1 owner=[SysUser: greg [uid=1000, gid=1001 home=/home/greg gecos=greg shell=/bin/bash]] idle=0(0) active=1 type=x11 class=user state=active timestamp=**Please do not post TeamViewer IDs**744968 service=sddm-autologin defaultCG= leader=666 audit=1 remote=0 rHost= rUser= killProc=0]
    2019/10/26 07:34:07.355 15056 **Please do not post TeamViewer IDs**26688 GX0 SysSessionInfoManager: observing sessions from logind is marked as reliable
    2019/10/26 07:34:07.355 15056 **Please do not post TeamViewer IDs**26688 GX0 SysSessionInfoManager: Session Information provided by VT [priority: 2]
    2019/10/26 07:34:07.356 15056 **Please do not post TeamViewer IDs**26688 GX0! FrameBuffer: Cannot access /dev/fb0, frame buffer support unavailable
    2019/10/26 07:34:07.356 15056 **Please do not post TeamViewer IDs**26688 GX0 SysSessionInfoManager::SessionAdded: adding session XSession: 0 [SysSession **Please do not post TeamViewer IDs** [type=88 vt=1 tty= pseudotty=0 info=1 id=1 user=greg state=user active=1 reliable=1]]
    2019/10/26 07:34:07.357 15056 **Please do not post TeamViewer IDs**26688 GX0 SysSessionInfoManager::GetOwnProcessSession: own session cache set to '**Please do not post TeamViewer IDs**'
    2019/10/26 07:34:07.357 15056 **Please do not post TeamViewer IDs**26688 GX0 Running on Qt 5.13.1
    2019/10/26 07:34:07.421 15056 **Please do not post TeamViewer IDs**26688 GX0 Initialised XRandR extension 1.6 (base=89 error=147)
    2019/10/26 07:34:07.428 15056 **Please do not post TeamViewer IDs**26688 GX0 MonitorInfo: [XRandR 1.2] CRTC eDP1 [email protected] [0, 0, 1920, 1080] - 1
    2019/10/26 07:34:07.428 15056 **Please do not post TeamViewer IDs**26688 GX0 MonitorInfo: [XRandR 1.2] CRTC 1 has no outputs
    2019/10/26 07:34:07.428 15056 **Please do not post TeamViewer IDs**26688 GX0 MonitorInfo: [XRandR 1.2] CRTC 2 has no outputs
    2019/10/26 07:34:07.428 15056 **Please do not post TeamViewer IDs**26688 GX0 MonitorInfo: [XRandR 1.2] CRTC 3 has no outputs
    2019/10/26 07:34:07.428 15056 **Please do not post TeamViewer IDs**26688 GX0 Virtual Desktop [0, 0, 1920, 1080]
    2019/10/26 07:34:07.434 15056 **Please do not post TeamViewer IDs**26688 GX0!! ResourceLoader: loaded file '/opt/teamviewer/tv_bin/resources/TVResource_en.so' version () is not matching with application version (14.6.2452)
    2019/10/26 07:34:07.434 15056 **Please do not post TeamViewer IDs**26688 GX0 Loaded language 'en', using locale 'en-GB'
    2019/10/26 07:34:07.435 15056 **Please do not post TeamViewer IDs**26688 GX0 InterProcessBase::SecureNetwork created
    2019/10/26 07:34:07.435 15056 **Please do not post TeamViewer IDs**26688 GX0 AutoLogin::Login: enabled: 1
    2019/10/26 07:34:07.435 15056 **Please do not post TeamViewer IDs**26688 GX0 AccountLoginStateMachine::Reset
    2019/10/26 07:34:07.435 15056 **Please do not post TeamViewer IDs**26688 GX0!! ApplicationLookOfflineState::ApplicationAppearanceOfflineState: state not loaded
    2019/10/26 07:34:07.435 15056 **Please do not post TeamViewer IDs**40512 GX0 InterProcessBase::StartTcpCommunicationInternal(): setting m_NetworkConnector to new TCP connector
    2019/10/26 07:34:07.435 15056 **Please do not post TeamViewer IDs**40512 GX0 Opening local TCP connection to 127.0.0.1:5939, tcp?
    2019/10/26 07:34:07.436 15056 **Please do not post TeamViewer IDs**93184 GX0 Local TCP connection established
    2019/10/26 07:34:07.438 15056 **Please do not post TeamViewer IDs**93184 GX0 SettingsIPCReception receive a SYNCHRONISE Settings command : UserSettings
    2019/10/26 07:34:07.438 15056 **Please do not post TeamViewer IDs**93184 GX0 Received Control_InitIPC_Response processtype=1
    2019/10/26 07:34:07.438 15056 **Please do not post TeamViewer IDs**93184 GX0 Received Control_InitIPC_Response runningProcesses=3
    2019/10/26 07:34:07.438 15056 **Please do not post TeamViewer IDs**93184 GX0 Control_InitIPC_Response: all processes 3 completely initialized
  • Hi, I did already respond to this but the forum has removed my post , so im posting again so sorry if this is a duplicate ,god dam it.
    Yes you are correct, i am trying to connect from my linux system to a windows client to offer support.
    My log:-
    Version: 14.6.2452
    License: 0
    CPU extensions: l9
    IP: 192.168.2.106
  • Hi, sorry but the forum will not allow me to post any response. I keep trying to post my log files but the forum just keeps deleting my posts.
    I would try pastebin or something but i suspect it would see me posting a link as "spam" to and remove that post to.
  • I shall keep trying to post my logs
    Version: 14.6.2452
    License: 0
    CPU extensions: l9
    IP: 192.168.2.106
  • attempt number 6 to post some logs. (i shall just paste them as plain text this time).
    Start: 2019/10/27 11:03:07.095 (UTC+0:00)
    Version: 14.6.2452
    License: 0
    Server: master13.teamviewer.com
    CPU extensions: l9
    IP: 192.168.2.106
    2019/10/27 11:03:07.103 26935 **Please do not post TeamViewer IDs**81472 GX0 SystemID m=1 s=1 f48ad995d1d94f05a2259fdf8e02a280
    2019/10/27 11:03:07.104 26935 **Please do not post TeamViewer IDs**81472 GX0 DynamicPasswordUIModel::ShouldShowDynamicPassword(): dynPw=1 allowIncoming=1 id=0 ka=0 lanAllowed=0 lanOnly=0 networkState=1 showDynPwd=0
    2019/10/27 11:03:07.420 26935 **Please do not post TeamViewer IDs**81472 GX0!! ApplicationLookOfflineState::ApplicationAppearanceOfflineState: state not loaded, Errorcode=2
    2019/10/27 11:03:07.421 26935 **Please do not post TeamViewer IDs**81472 GX0 ManagerHolderStateMachine: Switching from None to NotReady
    2019/10/27 11:03:07.421 26935 **Please do not post TeamViewer IDs**80256 GX0 ChatManager::ChatManager: created
    2019/10/27 11:03:07.421 26935 **Please do not post TeamViewer IDs**80256 GX0 ChatManager::Factory: ChatManager created
    2019/10/27 11:03:07.421 26935 **Please do not post TeamViewer IDs**80256 GX0 IncomingBetterChatCommandHandler::IncomingBetterChatCommandHandler: created
    2019/10/27 11:03:07.421 26935 **Please do not post TeamViewer IDs**80256 GX0 IncomingCommandRegistration::Start: registering for ready state properties
    2019/10/27 11:03:07.421 26935 **Please do not post TeamViewer IDs**81472 GX0 Initialised XFixes extension (base=87 error=140)
    2019/10/27 11:03:07.424 26935 **Please do not post TeamViewer IDs**81472 GX0 DBusStatusNotifier: registered at org.kde.StatusNotifierWatcher
    2019/10/27 11:03:29.133 26935 **Please do not post TeamViewer IDs**81472 GX0 Process received SIGINT from process: 0
    2019/10/27 11:03:29.134 26935 **Please do not post TeamViewer IDs**28992 GX0 XClipboard: Shutting down event loop
    2019/10/27 11:03:29.135 26935 **Please do not post TeamViewer IDs**81472 GX0 Chat::Stop: Stopping chat
    2019/10/27 11:03:29.135 26935 **Please do not post TeamViewer IDs**81472 GX0 ChatManager::UnregisterIncomingCommandRegistration: destroying incomingCommandRegistration
    2019/10/27 11:03:29.135 26935 **Please do not post TeamViewer IDs**81472 GX0 IncomingCommandRegistration::Stop: disconnecting ready state properties
    2019/10/27 11:03:29.135 26935 **Please do not post TeamViewer IDs**81472 GX0 ChatManager::~ChatManager: destroyed
    2019/10/27 11:03:29.135 26935 **Please do not post TeamViewer IDs**81472 GX0 IncomingBetterChatCommandHandler::IncomingBetterChatCommandHandler: destroyed
    2019/10/27 11:03:29.212 26935 **Please do not post TeamViewer IDs**87552 GX0 CTcpProcessConnector::HandleRead(): Socket gracefully closed (PID=26684)
    2019/10/27 11:03:29.212 26935 **Please do not post TeamViewer IDs**87552 GX0 CTcpProcessConnector::CloseConnection(): PID=26684
    2019/10/27 11:03:29.212 26935 **Please do not post TeamViewer IDs**87552 GX0 InterProcessBase::EventFunctionInternal(): IPC-Connection Closed
    2019/10/27 11:03:29.212 26935 **Please do not post TeamViewer IDs**87552 GX0 CTcpProcessConnector::CloseConnection(): Shutdown socket returned error 107: Transport endpoint is not connected
    2019/10/27 11:03:29.234 26935 **Please do not post TeamViewer IDs**81472 GX0 Shutting down System DBus
    2019/10/27 11:03:29.234 26935 **Please do not post TeamViewer IDs**81472 GX0 InterProcessConfigurationHub::SendToConfigurationHandler(): IPC not available, could not send command: CC=1 CT=110
    2019/10/27 11:03:29.234 26935 **Please do not post TeamViewer IDs**81472 GX0 interprocessbase::SecureNetwork destroyed
  • attempt number 6 at posting my logs, god dam.
    Start: 2019/10/27 11:07:15.618 (UTC+0:00)
    Version: 14.6.2452
    License: 0
    Server: master12.teamviewer.com
    CPU extensions: l9
    IP: 192.168.2.106
    2019/10/27 11:07:15.625 28874  GX0 SystemID m=1 s=1 f48ad995d1d94f05a2259fdf8e02a280
    2019/10/27 11:07:15.627 28874  GX0 DynamicPasswordUIModel::ShouldShowDynamicPassword(): dynPw=1 allowIncoming=1 id=0 ka=0 lanAllowed=0 lanOnly=0 networkState=1 showDynPwd=0
    2019/10/27 11:07:15.962 28874  GX0!! ApplicationLookOfflineState::ApplicationAppearanceOfflineState: state not loaded, Errorcode=25
    2019/10/27 11:07:15.962 28874  GX0 ManagerHolderStateMachine: Switching from None to NotReady
    2019/10/27 11:07:15.962 28874  GX0 ChatManager::ChatManager: created
    2019/10/27 11:07:15.962 28874  GX0 ChatManager::Factory: ChatManager created
    2019/10/27 11:07:15.962 28874  GX0 IncomingBetterChatCommandHandler::IncomingBetterChatCommandHandler: created
    2019/10/27 11:07:15.962 28874  GX0 IncomingCommandRegistration::Start: registering for ready state properties
    2019/10/27 11:07:15.962 28874  GX0 Initialised XFixes extension (base=87 error=140)
    2019/10/27 11:07:15.965 28874  GX0 DBusStatusNotifier: registered at org.kde.StatusNotifierWatcher
    2019/10/27 11:07:24.164 28874  GX0 XClipboard: Shutting down event loop
    2019/10/27 11:07:24.165 28874  GX0 Chat::Stop: Stopping chat
    2019/10/27 11:07:24.165 28874  GX0 ChatManager::UnregisterIncomingCommandRegistration: destroying incomingCommandRegistration
    2019/10/27 11:07:24.166 28874  GX0 IncomingCommandRegistration::Stop: disconnecting ready state properties
    2019/10/27 11:07:24.166 28874  GX0 ChatManager::Close
    2019/10/27 11:07:24.166 28874  GX0 ChatManager::UnregisterIncomingCommandRegistration: destroying incomingCommandRegistration
    2019/10/27 11:07:24.166 28874  GX0 ChatManager::ClearAccountChat: clearPersistently = 0
    2019/10/27 11:07:24.166 28874  GX0 ChatManager::ClearNonAccountChat
    2019/10/27 11:07:24.166 28874  GX0 ChatManager::~ChatManager: destroyed
    2019/10/27 11:07:24.166 28874  GX0 IncomingBetterChatCommandHandler::IncomingBetterChatCommandHandler: destroyed
    2019/10/27 11:07:24.213 28874  GX0 CTcpProcessConnector::HandleRead(): Socket gracefully closed (PID=26684)
    2019/10/27 11:07:24.213 28874  GX0 CTcpProcessConnector::CloseConnection(): PID=26684
    2019/10/27 11:07:24.213 28874  GX0 InterProcessBase::EventFunctionInternal(): IPC-Connection Closed
    2019/10/27 11:07:24.213 28874  GX0 CTcpProcessConnector::CloseConnection(): Shutdown socket returned error 107: Transport endpoint is not connected
    2019/10/27 11:07:24.231 28874  GX0 Shutting down System DBus
    2019/10/27 11:07:24.231 28874  GX0 InterProcessConfigurationHub::SendToConfigurationHandler(): IPC not available, could not send command: CC=1 CT=110
    2019/10/27 11:07:24.232 28874  GX0 interprocessbase::SecureNetwork destroyed
  • can someone please tell me how to post my logs , please!
  • Lets try a picture of my logs and see if the forum will accept that.
    [the link has been removed as per the community guidelines.]
  • you description is a bit confusing to me. I assume, that you want to do an outgoing connection from your Manjaro box to your dads ( windows? ) PC. right?
    Yes this is correct.
    Sorry i did already answer this but that was on one of my post that the forum has already deleted.
  • rolandg
    the logs show after a few lines already the shutdown and cleanup. there is a 2 mins gap in the logs.
    the problem must have happend already earlier.
    when I start TV here, i can see a 2nd thread running, dealing with networking.
  • The entire log is 3400 lines long and i dont have a clue what im looking at.
    I would post the entire log but after already having 8/9 post deleted from this thread already i just do not know how to.
    Why would they build logs that cant not be posted in their support forum ?
    Thx for your help but i dont know how to procede.
  • @rolandg
    does this mean anything? these are the errors in my log marked with a "GX0!!"
  • rolandg
    don't think so; my log file shows the same line.
  • Im still trying to figure this out but i still get all my posts deleted if i even attempt to show logs.
    What exactly do i need to remove from the logs that is causing them to delete the posts ??
    I need advice PLEASE.
  • @rolandgHay i found something interesting.
    I downloaded the tarball teamviewer_14.0.14470_amd64.tar.xz and i found i could run teamviewer directly from there and it connects (green light). So i remove my old installation > yay -Rsn teamviewer  then i try to install from the tar
    ❰greg❙~/Downloads/teamviewer❱✘≻ sudo ./tv-setup install
    -=- TeamViewer tar.xz interactive installation -=-
    Checking dependencies
    Analyzing dependencies ...
    All library dependencies (*.so) seem to be satisfied!
    QtQuickControls seems to be missing
    Serious Problem - installation should be aborted
    Missing libraries
    TeamViewer will not be operational without these libraries. Please install them and try again.
    Continue (y) or abort (n) ? [Y/n]? n
    what is Qtquickcontrols? how do i install it? why does running TV directly from the download work fine without it? what is wrong with the install from the AUR repos?
    Thx man.
    p.s. just checking i do have the following installed
    2 extra/qt5-quickcontrols2 5.13.1-1 (1.8 MiB 8.4 MiB) [qt qt5] (Installed)
    Next generation user interface controls based on Qt Quick
    1 extra/qt5-quickcontrols 5.13.1-1 (844.9 KiB 4.8 MiB) [qt qt5] (Installed)
    Reusable Qt Quick based UI controls to create classic desktop-style user interfaces0 0
  • hmm, just realised that it was version teamviewer_14.0.14470_amd64.tar.xz that was working directly from the extracted tar (although i still could not install it, see Qt error mentioned above)
    So 14.0.1447 will work but only directly from the extracted tar folder.
    14.7 will not even work from the extracted tar.
    Installing from the Arch AUR does not work.
    Looks like i can only use the 14.0.1 and only in its own tar extraction, i cant not install that either. What a dam mess or a linux version and this forum is no better since iv had to battle against most of my post being deleted by the bot. I do not even know if 14.0.1 will work/connect to more up to date clients, i shall have to test it some time.
    I would still like to install this app properly so if anyone has any suggestions i'm all ears. thx.
  • rolandg
    tv-setup seems to be a small wrapper around    tv_bin/script/teamviewer_setup
    that's a bash script, and at line 240 you will find the simple check for QtQuick controls.
    But the check does not work on Manjaro. check the output of
    $ packman -Qlq qt5-quickcontrols | grep qmldir
    I think teamviewer_setup could have an additional check for the directory   /usr/lib/qt/qml/QtQuick/Controls/qmldir
    ps: fixed cli above: the option on pacman is -Qlq   ( not -Qlp )
    means the message   QtQuickControls seems to be missing     is a false warning.
    the set of Qt libraries is good enough for TV.
  • your getting a bit over my head now but i can see i do have qt5-quickcontrols but pacman -Qlp qt5-quickcontrols throws an error :-
    ❰greg❙~/Downloads❱✔≻ pacman -Qlp qt5-quickcontrols
    error: could not load package 'qt5-quickcontrols': could not find or read package
    ❰greg❙~/Downloads❱✘≻ pacman -Qi qt5-quickcontrols
    Version : 5.13.1-1
    Description : Reusable Qt Quick based UI controls to create classic desktop-style user interfaces
    Architecture : x86_64
    URL : https://www.qt.io
    Licenses : GPL3 LGPL3 FDL custom
    Groups : qt qt5
    Provides : None
    Depends On : qt5-declarative
    Optional Deps : None
    Required By : kirigami2 qtcreator teamviewer
    Optional For : calligra
    Conflicts With : None
    Replaces : None
    Installed Size : 4.83 MiB
    Packager : Antonio Rojas <[email protected]>
    Build Date : Thu 05 Sep 2019 09:28:13 BST
    Install Date : Thu 10 Oct 2019 16:40:31 BST
    Install Reason : Installed as a dependency for another package
    Install Script : No
    Validated By : Signature
  • I have tried clicking "Continue" when trying to install from the tar's but when i run it it still just will not connect (remains red "Not ready ....")
     The only time it is working is from the older version directly from the extracted tar, none of the instalations have worked from any of the other methods or versions.
  • Ok so i have been able to install ver 14.0.14470 properly from the tar (i had to clean out /opt/teamviewer manually). I did try 14.7 again but it still fails.
    So 14.0.14470 does work but new versions of TV just do not. I hope this version will connect to more up to date clients otherwise im buggered we shall see.
    Does anyne know why i can install & run 14.0.14470 but not later versions?
  • (Sorry for double posting, but it fits better in this posting, because it's about Arch and the issue is newer)
    I have the same issue.
    I tried Google DNS, restarted the service many times, signed in with the browser and authorized my device, reboot etc. Also tried to install it from the TAR. Can't make it work.
    It worked previously on other OS, like MX Linux. But on Manjaro it just doesn't want to connect.
    System:    Host: manjaro-2019-11 Kernel: 5.3.8-3-MANJARO x86_64 bits: 64 compiler: gcc v: 9.2.0 Desktop: Xfce 4.14.1
    Network: Device-1: Intel Wireless 3165 driver: iwlwifi v: kernel port: f040 bus ID: 01:00.0
    IF: wlp1s0 state: up mac: <filter>
    Device-2: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet driver: r8169 v: kernel port: e000 bus ID: 02:00.0
    IF: enp2s0 state: down mac: <filter>
  • Yea im still waiting for an answer too :(
    Did you try 14.0.14470 ? https://teamviewer.app.box.com/s/ksjaac6bjv2dh6r8wha5akmot4zdy7tj as i did manage to get that version to work after completely cleaning TV of my system first.
    I still don't know if this older version is compatible with the current version of TV client because in the end i manually traveled 90 miles to go and assist my dad and his printer problem so i have never actually tested it but its connecting ok.
  • My father is about 10.000km away, so that's not a solution for me. But actually I just use TV to fix my father's computer :-D
    Finally I can connect and login with my account! I saw the solution in the forum, but I didn't have the link. Thank you!!!
    Haven't tried to connect to another computer yet.
  • The solution worked for two weeks. But now 15 was released. My partners updated and I can not connect with 14 any longer...
    And when I install the current 15 version, I have the issue again, that I can not connect. So we are again back at square one...
  • Thats really odd cos when i installed TV 15 it connects fine. Try a complete removal of TV and its settings and a re-install (dont ask me how though but maybe yay -Rsn and the a system wide search for teamviewer remnants).
Howdy, Stranger!
This Week's Leaders
