Teamviewer ID
Hello guys,
I use teamviewer with win 10 home.
I need to know where the ID is stored (windows registry or anywhere)???
I would like to be able to retrieve it every time I turn on the pc.
Thanks in advance
  • Thank you very much for the collaboration.
    It's just what I was looking for!
  • BPM
    BPM Posts: 1
    How do you get there?
  • run-->regedit
  • platinum101
    platinum101 Posts: 1
    Hi
    pls have been trying to connect with a computer over 1 year , the issue i am having is it never shows my ID and also I am using 4GLTE wifi with is connected to the computer but the teamviewer app always says it is not connected to the internet, why???????
  • samsantos4u
    samsantos4u Posts: 1
    I'm using a chromebook and I can't find my Teamviewer ID and Password. Where can I find this so I can share it for remote access when I travel?
  • Sparkey1305523
    Sparkey1305523 Posts: 1
    That user ID is hard to find where is its
  • FionaSmith
    FionaSmith Posts: 1 Newbie
    edited March 2
    Thanks for asking for the same confusion anyone there to help.
