Ver. 10 on a Mac running OS Catalina
DeweyH
DeweyH Posts: 1
I need to run version 10 so that my internet provider can access my machine. After downloading the v10 it will not open and gives an error message stating that v10 needs an update. Any help will be greatly appreciated.
  • Yuri_T
    Hi @DeweyH
    You are required to use TeamViewer version 14.7 on a MacOS Catalina.
    Note: Currently, TeamViewer 14.7 is live as an Insider Build for open testings for all our participants of the Insider Program and all of you being excited to test our pre-releases
    IMPORTANT: We do not recommend using an Insider Build on your productive system!
    Hope this information will help you.
    Yuri
  • Adidraso
    What do you want to say? that I will not be able to licensed ver.10 on macos anymore. I hope you are wrong and the tw team is very quick to provide an update. I need to use tw10 on my macos catalina. I need to connect/control/transfer files from/to PC. I don't want to buy another version of tw, what the **bleep**!!??
  • OlegB
    OlegB Posts: 2 ✭✭
    Does 10 license work in teamviewer 14.7?
  • Adidraso
    No, you need to buy update.
  • OlegB
    OlegB Posts: 2 ✭✭
    So what can we do about this problem? When can we get version 10 for catalina?
  • Gtek
    Gtek Posts: 1
    Waiting for the solution as well.
  • JoshP
    JoshP Posts: 895 Community Manager 🌍
    Hello all,
    Thank you for your posts.
    Kindly refer to the Support Operating Systems article:
    2019-11-20 11_42_11-Which operating systems are supported for which TeamViewer versions_.png
    MacOS 10.15 (Catalina) is only compatible with TeamViewer versions 14.7 and higher.
    It will not be possible to install TeamViewer 10 on a device running MacOS 10.15 Catalina; TeamViewer 10 is only compatible up to OSX 10.11 (El Capitan).
    Josh P.
    Senior Community Moderator
  • Adidraso
    Hmm, how do you explain though that TeamViewer 10 worked on macOS until Catalina update? It should no longer work after version 10.11!
  • Yg
    Yg Posts: 1
    We payed for lifetime licence. But not our licence became dead.
    Please solve our problem, using the same version or licence on macos Catelina. Because this is not option for us using Catalina. It must upgrade without our opinion.
    Thanks for your help
    Sincerely
    Yusuf
