MacOS - Moving files not working
gr8
Hi
Im using the latest Teamviewer on both my Mac's, both running Catalina.
If I connect to the remote system, I'm not able to move files (per drag & drop) on the remote mac. Also the the Finder menu, the cut position is not available.
So I have to copy the files and then delete it. And thi
Is there anything I can do to get this to work?
Thanks for your support.
It would be really nice to get a response... maybe from a Teamviewer member?
I need to know if I'm doing something wrong or if it's just like that...Thanks.
