The computer that I connect to now has a black square for a pointer. How can I fix?
Same exact issue here.
HP Envy running Windows 10, new install.
I am having the same issue. Except I see the cursor inside the black box
Screens are on.
Dear Metis1234,
Is it possible, that the screen on the remote side is turned off or not connected. This might be the reason why your cursor is displayed incorrectly.
Could you please check this?
I hope this was helpful!
