Problem to get a connexion with a remote computer
When I try to connect to a computer, I always got the following message (pop up box):
"Version out-of-date: Update the remote TeamViewer". The proble is that I'm running that latest version of TeamViewer, and the TeamViewer QS I want to connect is alos the latest one.
I'm working with a Mac, running the OS version 10.15.2.
How can I solve this problem?
Thanks in advance & best regards,
Marc
    Hello @marcooooo
    What is the exact TeamViewer version that is running on your mac?
    You can verify this by going to TeamViewerAbout TeamViewer on the top left menu.
  • marcooooo
    I'm running the 15.0.24.
    I also try to install a previous version and got exactl y the same problem. Could the reason be with my OS?
  • marcooooo
    Hi Jean,
    Fantistic : the problem is now solved!
    Thanks a lot!
    Marc
    Hello @marcooooo,
    This is great to hear.
    We hope to see you soon again on the Community!
    P.S: We are sorry for the inconveniences caused though...?
